I haven't pushed snow with a Pioneer, but many, many, hours logged on a tractor/plow and would add the following for consideration: 1) The Pioneer is relatively small and depending on what kind of snow you generally get (wet vs. fluff) then that would be a factor in plow size and personally think the 66" would a great size; b) I would consider sitting some sand bags on the rear rack for traction and help offset the load created on the front suspension and c) If pushing on a concrete surface, then consider putting a rubber squeegee on the plow to avoid scratches.
