P1000 8 Ply Tire For east coast -POLL
Pick your top three 8 ply UTV tires
  • STI Roctane
    Votes: 14 20.0%
  • ITP EVOs
    Votes: 16 22.9%
  • Tusk Terrabites
    Votes: 31 44.3%
  • EFX motoclaw
    Votes: 4 5.7%
  • Maxxis Carnivore
    Votes: 15 21.4%
  • Mastodon HT
    Votes: 0 0.0%
  • Sedona Rockabilly
    Votes: 7 10.0%
  • Tusk TriloBite
    Votes: 8 11.4%
  • Braven Berserker
    Votes: 5 7.1%
  • Tensor regulator
    Votes: 11 15.7%
  • Kenda Bear Claw HTR
    Votes: 6 8.6%
  • QuadBoss 846/446
    Votes: 5 7.1%
  • Rip Saws
    Votes: 4 5.7%
  • Maxxis Carnivore
    Votes: 0 0.0%
    Votes: 1 1.4%
  • ITP EVOS
    Votes: 0 0.0%
  • Total voters
    70
Wonder what ply they are then?
Not sure but I’d say less than 4. Roctane is one of the few tires that list “8 ply construction”. Now they got a 10 ply construction tire available.
Reactions: sharp, JTW and BWAF
Interesting.. I hadn’t noticed the wording. I wonder what an 8 ply rated construction actually means?
Reactions: sharp and BWAF
471022A0 9D72 4D3C 8E9C E99B16802890
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
May I ask what brand and size of wheels are you using are where did you buy them---out here in NB I will be ordering online and picking up "cross border".
I may have misled you - I still have the Honda 14" deluxe stock aluminum wheels. The local shop refers to "glued rims" as "bead locked" I've never had a problem with bead leaks, although these run flats sound like they probably need a proper bead lock rim. Will give them a call to confirm. This promo video shows bead lock rims: RP Spartan Atv Utv Run Flat Tires – GPS Offroad Products
Re cross border savings, as you know depends on what it is. i.e. Maxxis Bighorn 2.0's fronts are close ($178 Vs $161 CAD using 30% exchange) No question about buying Spartans in the US (i.e. rear tire $386 Vs $223 CAD incl 30% exchange)
Honda1000-5
Honda1000-5
216
342
New Brunswick Canada
Thank you. How is the ride and handling compared to the bighorn 2.0's? Do you use a sealant?
Reactions: BWAF and sharp
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
Haven't got the tires yet (with Christmas coming, truck insurance and winter here now, will probably wait until March) Will let you know when I get them on.
Good news, just called Goldspeed and they said bead lock rims are not necessary with the RP Spartan tires. Just use a good rim sealant.
Neohio
Neohio
Beast of the East
21,711
92,784
Painesville Ohio
Ragnar406
Ragnar406
The Great Bald One
4,459
17,081
Bella Vista, AR
When I was doing all my reading into tires I seem to remember somewhere them saying that Ply rating does not mean what it use to mean but they still put it on tires because everyone likes that metric.
"The load range/ply rating branded on a tire’s sidewall identifies how much load the tire is designed to carry at its industry specified pressure. Today’s load range/ply ratings do not count the actual number of body ply layers used to make up the tire’s internal structure, but indicate an equivalent strength compared to early bias ply tires"
also the rating can be different for sidewall so a 8 ply tire can be say a 4 or 6 on sidewall.... fairly sure the Bighorn 2.0 are like 2ply on the sidewall....
unfortunately I think weight is a good indicator - year we don't want the heavy tires but a 40lb tire in the same advertised size as a 32lb tire is going to be a heavier duty tire and probably have stronger sidewalls..
70,198
I agree. There is no official ply rating for atv tires. I really liked the carnivore but the weight rating barely covers the rig and that's at 18 psi.
Ragnar406
Ragnar406
The Great Bald One
4,459
17,081
Bella Vista, AR
I like the look of the carnivore's and a couple people I talk to that have them and all say they do good on "everything but wet rock" to which I respond what does good on Wet Rock?
Honda1000-5
Honda1000-5
216
342
I too like the tread depth and pattern of Carnivores but the load rating is low and they are rather light weight which concerns me for punctures. I examined a pair at my dealer and the mid tread area seemed very thin and soft---hard to beleive it was "8PR" . I want to replace the Maxxis BH 2-0's with something more puncture resistant for back country confidence.My thoughts are going more to Roctane XD's or even the Spartan RP Run Flats. I am looking at load rating and weight as perhaps more important than Ply Rating.
Something to consider. I went through the same thing and got the roctanes like mentioned many times above. They just beat the vehicle and passengers. My suspension and steering bushings wore quickly.
Part to consider: Now I’m running a softer, lighter and cheaper tire and carry a tube, plugs, CO2 kit and 12v compressor. My spare tire stays in the truck. Got to have bead locks to make easy trail side repair use of the tube though.
