P500 A arm brace
ComeonHonda
6
Ohio
Where can I buy a brace that will keep my front A arm tabs from ripping off of the frame? Thanks.
Reactions: J80
63,389
Haven't seen any for a 500..
I tried to make some myself for the P1k but failed. lol.
Later I saw someone made some, but they too had some fitment issues like I did.
Recommend finding a good welding shop.
Shouldn't take about an hour for them to weld in a gusset brace.
I'll post mine in a sec.
Reactions: J80
63,389
Triangle price welded in. Can't even tell its added.
40f11e1671e1089b9d6b07263e7663b7988d291d142c6a3362554465c4e323d1
ComeonHonda
6
Ohio
I saw two different ones. One made by riding dirty and another by ss fab. Can't find a good contact for either.
Reactions: J80 and pappyo
P
pappyo
593
2,377
Welcome from Central N.Y
RED is the 1st Color All other Colors followed hopping to catch some of the Glory Honda hopes they sell
Haven't had the need for a BRACE - will keep watching how this is resolved - Before the NEED develops.
Anyone have a picture of damaged area. ( Clarifying Damage ).
Make a BRACE & install Before Damage happens & Weakens the area - another Preventative Maint. item for the list - ( with Tracks on in winter couldn't hurt )
Reactions: J80
ComeonHonda
6
Ohio
20210410 083717
ComeonHonda
6
Ohio
View attachment 274813Besides the one that ripped the frame, the other three are soon to fail. I can see hairline cracks in the welds. Also there was rust inside the there. I believe it would be a good idea to remove the plastic plugs that are in the front of the frame tube to allow the inside to dry.
Reactions: futzin
F
Fischer
209
321
The woods
How often does this happen with these pioneer 500s
Bomersteve35
98
307
53
Portland or
  2. Other Brand
Without looking in the shop at it could a guy take the bolts out and thread some machine bar on each end and run it all the way threw both mounts and install a center sleeve between the two. Maybe even weld the center sleeve to the frame with a flat bar?
P
pappyo
593
2,377
C-on-H
Please describe what put the amount of Strain to cause the mounts to bend & tear frame.
This will help to know the strength needed to make & prevent future event of this nature.
Reactions: Fischer
futzin
futzin
3,097
22,287
Kentucky
. . . welcome to the forum . . .
F
Fischer
209
321
The woods
C-on-H
Well said.
ComeonHonda
6
Ohio
To me, it is poorly designed. I can see it happening on all of them. Just give it time.
ComeonHonda
6
Ohio
All 4 of mine have cracks in the welds
P
pappyo
593
2,377
In the picture supplied.
Cannot See where the Weld is Broken --- Can See Frame IS ( Ripped & Torn )
Come on Honda
Please tell the ( Rest of the Story ) takes some serious Leverage & Pressure to Rip Even THIN steel.
Expanding on bomersteve35 sleeve idea.
Not that difficult to add additional support in that area.
Using sleeves with welded washers on the ends ( extra washers for snug fit )
Weld a side to side Cross Brace between sleeves.
Another side to side Cross BRACE on TOP of frame.
Bolt the two braces as close to the INSIDE of main frame as possible & a bolt down through the center of both braces.
Could be done as a bolt on kit ( if Honda holds close tolerances on A -Frame mounts )
If Not the cross brace welded to sleeves could be 2 piece overlap 1/4in × 2in flat stock after in place drill & bolt together then drill center bolt.
REMBER the Damage in future will go to the Next Weakest Point -- ???
Reactions: Fischer
stobiadas
stobiadas
114
460
K0E1X0
That looks like the machine was "jumped" repeatedly? I can't imagine that kind of deformation happened with regular use.
Reactions: Fischer
bowhunterbill
bowhunterbill
408
1,261
Bozeman, MT
C-on-H
X2. How hard are you banging it to do that damage?
Reactions: Fischer
rustyneversleeps
rustyneversleeps
379
1,828
Montana
Is Outkast the only option at this point for arms for the 500/520?
