P1000 A arm question
Beefmeister001
5
5
York pa/ logan wv
Let me say that I've read a lot of posts but a few things didn't seem absolute. Let me state what I would like to do.
1-Forward A-arm Kit | CFab
2-2" spacer on front and 2" spacer on rear
3-use stock rims
4-put 29" or if safe, use 30" tires.
I am looking more for clearance without a basic lift.
5-change to fox shocks when I have an extra lottery ticket winner.
Reactions: johnboy88 and BWAF
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Dont see anything wrong with any of that. You will be fine with 30" tires and that setup
Reactions: BWAF
DDDonkey
I like what your saying there but I would not put 2" spacers on the front, I had 1.5" spacers with a lift and the stock tires rubbed at full lock. Oh and I would upgrade your skid plate too. Good luck with your build!
Reactions: BWAF
Beefmeister001
5
5
York pa/ logan wv
I will buy new tires but I like the rims. Should I change the rims?
Also, 2" spacer or 1.5" spacer.
Btw, I'm not gonna put a lift.
As for tires, any preference for all terrain? Not using it for mudding, just if it appears I want to go through it.
Reactions: BWAF
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Pretty sure the CFab arms have a 3" lift built into the arms and can run a 32" tire. The SATV and Highlifter arms do not have any lift built in and are good for 30's.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
I had 1.5" on the front with 29" tires (measure 28) and would barley rub under full lock and compression. When i had stock tires it never rubbed. That was the HL lift. The CFab is 2" offset and 3" lift. Would be fine with spacers and larger tires.
Reactions: BWAF
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
If your staying with factory wheels than 2" all around are good. If you go to new wheels then 1.5" in the front and 2" in the rear. Facotry wheels have different offset in front and back
Reactions: BWAF
SLSHonda
SLSHonda
34
Florida
If I did everything that beefmeister wants to do without the spacers then I’d be good to clear the 29” tires right?
