P1000 A-arm tab and Crossmember supports
chipolariverman
chipolariverman
67
Malone, FL
So I just purchased a 2020 P1k3 that I will be hog hunting out of 2 to 3 days a week and will be putting about 50-75 miles a week on. I have been reading this form for several months now and I have questions regarding the A-arm tab tear out and bending or adding Crossmember supports.
Regarding the tearing out of the A-arm tab on the front upper A-arm is this happening at a high rate of speed and you coming into contact with a rock or tree? I have read a lot of the post on this and I know some have stated I wasn't going 5 mph and it just fell off!?!? I would like some honest comments on this. I am in the process of installing a Tough Country front bumper and 814 Shocks so now would be a great time to beef up the tab if it is something that is just going to fall off while I am going around a field and hit a gopher hole at 5 mph which is very possible.
I live in North Florida so there are no rocks to crawl over however I do on a fairly regular basis crawl over logs. I have purchased and will be installing the 1/2" UHMW Factory UTV full skid plate that is the full width of the buggy. My question is will this be enough to protect the undercarriage of the machine? Those that are damaging the undercarriage I "assume" are rock crawling and that is where the damage is coming from? Some of you that have added and/or beefed up your undercarriage can I get your opinion on this?
Reactions: TxDoc
chipolariverman
chipolariverman
67
Malone, FL
Make sure the bolt is torqued properly and don’t hit a stump in tall grass.
You’ll be fine.
That's not very reassuring, LOL!!!
Man if someone could fab up the bolt on brackets like I saw one member make they would sale like hotcakes. They bolt to the upper A-arm bolt and the 2 bumper bolts with a gusset on top.
JenElio
JenElio
75,053
677,066
Loxahatchee, florida
Factory utv 1/2" skid will protect everything down under . like stated, just don't haul a** in tall grass where something big can sneak up on ya and do some damage. I've put about 700 miles on mine riding a bit of everything and haven't had any issues 🤞.
Good luck!
Vikes79
Vikes79
SKOL!
11,776
114,182
South Dakota
  2. Talon X4 LV
The P1k5 is a lot tougher than people give them credit for.
I routinely load mine up with 60 gallons of spray, and navigate rough ass pastures all the time with it.
Yank the sprayer and off road over the weekend.
There’s thousands of these rig running on farms and ranches getting the crap beaten out of them without issue.
I agree with lee about stumps etc in the grass.
In an open field with knee high grass, you wouldn’t take your truck across an unknown field at 50 mph....so why would you do the same with an atv / utv?
I see this all the dam time however!
322,675
The 1000 carries a lot of weight so the right hit can tear it, but usually stumps like said or driver error. Although it’s not common there have been just a few that had a questionable weld.
If you’re worried you can purchase a SuperATV frame stiffener which will help strengthen it up some, but for the most part I wouldn’t worry about it.
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
The SuperATV kit does nothing for the upper mounts and I've yet to see a lower mount fail.
bwetzel
bwetzel
57
151
Illinois
not a fun time when it happens.
1924EA0B C07F 4B96 B1EB 54296CA12061
bwetzel
bwetzel
57
151
Illinois
@bwetzel can you give some details behind this? What caused it? Looks like you were stuck pretty good based on the mud/debris on the a-arms.
this falls into the “driver error” category. third and fastest attempt up a creek bank trying to straddle ruts. almost made it to the top but slid into the ruts and the impact broke the tab. ruts were deep enough it hit bedrock.
Ohio4x4
Ohio4x4
I brought the dishwasher
1,529
15,424
Ohio
Before my satv arms I hit a large rock with the drivers a arm and bent both upper and lower arms no tab damage. Earlier this year while at tackett a few of us hit a submerged obstacle. It bent my tie rod and cracked the weld on the passenger side upper a arm tab. Both stopped the machine in its tracks both moving approximately 10-15 mph.
322,675
I had lower fail twice and I’ve seen several others. And yes you are correct on it doing nothing for upper
Reactions: TripleB
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Start at post 813 and go from there...i documented add in a crossmember, upper a arm tabs and crossmember supports. I also have the SATV frame stiffener.
5,492
25,268
Although I don't have a P1000, I try to be proactive since I'm usually solo. Snuffnwhiskey mentioned tying that upper mount to the two bumper bolts that are right there with a piece of angle iron. If the stock A-arm bolt is long enough, this would be a fairly simple reinforcement, something I'd do as soon as I could.
Reactions: CumminsPusher
chipolariverman
chipolariverman
67
Malone, FL
@GlockMeister so you just welded in some gussets, you didn't make a bolt on reinforced bracket like I was talking about?
I assume it has worked fine?
Regarding the crossmember beef up I assume it is due to all of the rocks in your area?
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
I don't like the idea of a bolt in support. In my opinion the bumper mounting bolts are already undersized and prone to failure in a winch pull or recovery, if they are utilized as support for the winch. I've also seen a few guys that broke them off just installing and removing them multiple times. Either way, I welded my gussets on the upper and lower mounts and added weld washers
IMG 20200827 165319
IMG 20200827 165325
IMG 20200827 165333
I welded my frame supports too
IMG 20190527 162418
I did bolt in my subtransmission crossmember
IMG 20200628 122055
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Just welded..I haven't had any issues with thwm. Yes my crossmembers were bowed quite a bit due to the area annnd terrain we ride
