Is there a Honda accessory sub harness for the Pioneer 1000 like there is for the 500 and 700?
Not that I know of but am interested to know if I’m wrong?Is there a Honda accessory sub harness for the Pioneer 1000 like there is for the 500 and 700?
Well hell!!! Why would Honda provide me an easy approach to accessories on my 500, and not the 1000, which is almost certainly going to have more accessories?Not that I know of but am interested to know if I’m wrong?
To piss you off! Lol. There good at thatWell hell!!! Why would Honda provide me an easy approach to accessories on my 500, and not the 1000, which is almost certainly going to have more accessories?
If you don't use your cigarette lighter port, i'm sure with a little digging I can find the mating plug for it and create a harness for you. I may even be able to create a piggy back.Is there a Honda accessory sub harness for the Pioneer 1000 like there is for the 500 and 700?
Well, I’m just getting started, but I’ll have a sound bar, light bar, cube lights, winch, USB’s, rock lights, whips, etc., and not all of which I need on keyed power. I’ve got no problem wiring it all conventionally, it’s just that the sub harnesses were so nice, handy and convenient on the 500 and 700.What are you looking to wire?
I don’t use it. I was just hoping that there was a plug and play sub harness for the 1000, like there is for the 500 and 700.If you don't use your cigarette lighter port, i'm sure with a little digging I can find the mating plug for it and create a harness for you. I may even be able to create a piggy back.
this panel would be perfect for you.
https://www.amazon.com/MICTUNING-12-Slot-Relays-Metallic-Automotive/dp/B075M4PRG2/?tag=sxsweb24-20
Would allow you to wire some time of the relays key on, some with constant power.
If you want to use the cig lighter plug for power, i'll see if I can find the mate for it.
It can be sealed with a tube of 3m potting compound.That's not sealed at all. I'd rather have something sealed but at least it's cheap
Is that something like this??For a little bit more can get a variety of choice that are configurable and fully sealed. I like my Cooper Bussmann box. Easy to assemble and waterproof.
Metri-Pack 280 Sealed MINI®/MICRO® Fuse & Relay Panel - 30 Amp, Partially Bussed
Yes. I ordered the Bussmann 15303-2-2-4. It's currently unavailable on Amazon for some reason
Yes, that would be great, thanks.If you want to use the cig lighter plug for power, i'll see if I can find the mate for it.
Indeed, thank you for that!This is a really good installation reference if you're interested in some reading before you install
DIY Bussmann RTMR Fuse Block, Part 4 – Wiring and Schematics | Bodenzord
Hmmm, it’s out of stock on eBay too. eBay does have the 15303-3-2-4. Is there an important difference in the two??Yes. I ordered the Bussmann 15303-2-2-4. It's currently unavailable on Amazon for some reason
I'll try and get it done tonight.Yes, that would be great, thanks.
Awesome! Tapping the cigarette lighter would provide keyed power for backlighting the switches is presumably the idea???I'll try and get it done tonight.
