P1000 Accessory sub harness
It is a bit of an expense. It might be easier or cheaper in the long run to find a fuse panel that is already wired up.
Blue Seals.......Shrink Tube??????????
Reactions: sharp
There is a Honda subharness that just plugs into the back of the cigrette lighter.
Sharp, any idea whether or not this Honda subharness can be obtained individually and separately from buying the entire winch package??
Reactions: sharp
Me no comprehend.
Sorry, I had been trying to ask you in various ways what the blue seals are (that you told me to look at in Todd’s link) Do they serve the same purpose as shrink tube??
Reactions: sharp
Neohio
Neohio
Beast of the East
21,538
91,150
Painesville Ohio
They are not a replacement for shrink tube. What they do is seal the connection at the back of that particular fuse block. It is what helps connections become weatherproof.
In this image, you can see the seals crimped onto the wire. The below is a "weatherpack" 2 wire connection. If you do not use the seals, the connection is compromised.
Capture29
Reactions: sharp
sharp
sharp
3,757
14,955
Tennessee
Surely they will sell just the harness. May have to contact the dealer. It's a simple plug and play harness. I'll try to look around when I get back from drinking lunch margaritas .
Reactions: Mudwing
Ay caramba!!!! Now I get it. Thank you......
Reactions: Neohio and Mudwing
Thanks, lol.
Did you have too many lunch margaritas lol...:D:D
Reactions: Mudwing
If you want to use the cig lighter plug for power, i'll see if I can find the mate for it.
Were you able to find this??
Neohio
Neohio
Beast of the East
21,538
91,150
Painesville Ohio
I ordered a bunch of different options yesterday. Hopefully everything is delivered Friday. I have to pull the front tires to get my fat assets far enough into the machine to remove the plug and compare what I bought.
You will be the first to know once I get that deep.
Reactions: sharp
Ok bro no worries then. I wait patiently. Thank you!!!
Reactions: sharp
Neohio
Neohio
Beast of the East
21,538
91,150
Painesville Ohio
Reactions: ToddACimer
For a little bit more can get a variety of choice that are configurable and fully sealed. I like my Cooper Bussmann box. Easy to assemble and waterproof.
Would you happen to have a link for ordering the blade fuses and mini relays for the CB box??
Neohio
Neohio
Beast of the East
21,538
91,150
Painesville Ohio
