P700m4 Accessory sub harness
Dpetrocik
Dpetrocik
50
71
Negaunee, MI
IMG 2079
IMG 2077
Where exactly do you connect this harness?? I'm going to use it for my key on for my winch power instead of splicing but I can for the life of me find where t plug the thing in??
Reactions: SFC
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I'm guessing you've already checked the fuse box on the passenger side front fender? That would be my guess
Reactions: swsebek
Theron
Theron
50
30
Anchorage Alaska
Reactions: Tflynn
Dpetrocik
Dpetrocik
50
71
Negaunee, MI
IMG 2084
Said heck with it and got this harness, plugs right in and has 4 sits for accessories! Pop the cap off the red harness coming off the pioneer and its plug n play.
Reactions: swsebek
Whistled03
Whistled03
36
32
Canton, GA
View attachment 26769 Said heck with it and got this harness, plugs right in and has 4 sits for accessories! Pop the cap off the red harness coming off the pioneer and its plug n play.
what is that looks like distribution panel that has the black, blue, yellow, red wires coming from it? Looks like a large relay maybe for winch or is it something else?
Becht313
Becht313
35
75
New Hampshire
08Z08-HL5-A00
$10 from the dealer in stock. Says it's for the 500 but plugged right into my 2017 700-4
Used the same harness to power the winch switch on my 17 p-4 deluxe. 12 volt switched, no issues, plug and go. I also ordered the harness the machine calls for just to see if it's any better. 2 cents.
Dpetrocik
Dpetrocik
50
71
Negaunee, MI
I have it powering my winch as well. Been plowing all winter and zero issues. I plan on wiring my small light bar and a speaker into it as well.
F
Fraunky12
5
0
Mount Bethel, Pa
With this harness does it only supply power of the key is On? Im looking to wire small auxbeam pod lights for stacking wood etc. @ night. If that’s the case I may add an auxiliary battery just for lights. Thanks for any info
