G
Good afternoon!
I've got the blinker/horn kit coming from the store for the 2023 P1000-6. While running the main harness from front to back, I'd like to plan ahead and run some additional wiring while I'm at it (make a dummy harness). That way if I decide to add accessories near the rear of the rig or even in the middle at a later time, I can save time by not having to drop the skid plate and navigate the wires over and over.
Not specifically asking about which gage of wire (there's threads I've found on that).
What are the best options for creating a "harness" on your own? I've seen things such as duplex and triplex wire, is that a better route than just getting a spool of different colored wire and making your own? What type of sheathing would you recommend for those? In terms of wire ends, what would be the best option for a quick plug/play setup - IE, what's the official name for the plug types similar to what come on the factory accessory switch wires under the hood? Lastly, does any big-box store carry these supplies readily? I would rather not wait on an amazon order every time I wanted to initiate a project.
Tagging @Hondasxs as it appears you must create most of the harnesses for the store.
Thanks a lot for your time.
