Acting like seat belt isn't pushed in. - SOLVED
scottkooch
scottkooch
67
241
SO MN
  1. Talon X4 LV
After doing the normal 3200 mile oil changes and diff changes. 1000x-4 FLV ran perfect up and down the street a couple of times. 5 miles total. Went to go to the gas station and had a bog a couple of times in the 3 miles to the station. Added gas and left, machine then would not go over 13 miles an hour. Seatbelt light goes off when I put belt on. Looked at that connection and it looks good. Checked oil and sub trans and both are good. Any one have any ideas where to look next?
scottkooch
scottkooch
67
241
SO MN
  1. Talon X4 LV
No codes flashing and it revs up past 6000
Dankathy
300
855
Possible bad gas? But if it bogged on the way to the station it seems unlikely
scottkooch
scottkooch
67
241
SO MN
  1. Talon X4 LV
I don't think that is the problem, It ran fine before with the same gas for at least 70miles. Tank was at just under 1/2 a tank. I had just replaced the 2" seat spacer in the back of the drivers seat with 1 1/2" spacer. Thought maybe the seat belt sensor wire got pulled out, but it seams seated well and the light goes out when I put my seatbelt on.
5,759
26,451
That brings up the old mechanic's meme - where were you last? Since you just changed the seat spacers, you were right at the point of failure. I'd have a closer look at that connection and the wiring going into the seatbelt buckle. I understand that the dash light goes out butt ...
scottkooch
scottkooch
67
241
SO MN
  1. Talon X4 LV
Thanks CID, that was my 1st thing to do this AM. I going to pull the connector apart and see if I can reconnect or just jump it. It was late last night when I got to look into the issue. I am also going to take the grounds apart behind drivers seat and clean them. Start easy and work to the harder.
scottkooch
scottkooch
67
241
SO MN
  1. Talon X4 LV
Update on this. I pulled the seat belt connecter apart, sprayed with contact cleaner, re-installed and drove with no difference. Went to next easiest and a known issue on these machines, the ground cluster under driver side rear seat. Pulled all the grounds apart and cleaned them and scraped the metal clean. Re-installed all the grounds and tightened. Drove the machine and all is well now. 🥹
These ground points are so pragmatic. I need to do some thinking on a better way to find ground. Any buddy out there come up with a better way? Thanks everybody for the help on this. This forum is so great, filed with very knowledgeable and nice people, it's awesome!
scottkooch
scottkooch
67
241
SO MN
  1. Talon X4 LV
Ok, before this happened with the ground, I was going to post about the mods and service I just got done with before this riding season starts for us up here in Minnesota. I did the 3200 mile oil changes using Honda HP4M 10-30 in sub-trans and Mobil 75-90 in the diffs. Normal Honda GN4 in engine. I like how the HP4M in the sub trans quieted down the shifting. I checked my filter, and as you can see in the attached pictures, both filter and filter box are like new after 2600 miles. I put in a new air cleaner after I installed 10-80 Dirt Sports pre-filter kit at 800 miles. Being the test 4 seater for him, It was very a nerve wracking drilling a 3 1/2" hole in the back fender not knowing it would fit. It sure was worth it though. I added a couple cube lights by the side mirrors and changed out the rocker switch for the turn signals for the new turn levers on the XTC turn signal kit. Should be ready for the local trails to open up the 15th now. As I mentioned before, a big thank you to all the great people on this forum for the help fixing these rigs and for helping me empty my bank account on mods I see here.
Air cleaner Air box Cube Xtc
116,574
After u get them all cleaned, put some dielectric grease on there. It will Deter any crud from getting into the contact area. Done this with all my grounds on both rigs and it I have no ground issues.
Now before I get chastised by the authority here, here is the ground cluster I cleaned under the rear seat driver side. Pictures to prove it happened.
No need to prove it happened. Thats reserved for FNG's with no pic of there rigs. Or people with some weird ass issue thats too good to be true! ;)
scottkooch
scottkooch
67
241
SO MN
  1. Talon X4 LV
Thanks for the advice on the grease. I'm going to try and find a wire brush, scrapper and clean up the machine side a little better, then I'll add the dielectric grease. I always add that to any connecters I take apart or add. Good stuff.
