Adjusting Valves Yes or No
SEW
24
16
Yeah it really wasn't bad, and this was my first time doing it on anything. Hardest part was reading the Top dead center mark on the flywheel through that inspection hole!
How did you read that mark? I have the service manual which shows a drawing the doesn't look like what I'm seeing thru the hole. I just used a traditional method to find tdc.
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
I have a sideways "T" on my flywheel as opposed to the right side up "T" shown in the manual. I had to rotate the flywheel maybe three revolutions before I realized it. Maybe yours is like mine, maybe they all are and the manual is wrong? Really you have to be a contortionist with super vision to be able to see it!
SEW
24
16
Thanks. I'd adjusted mine at about 70 miles. Now have ~250 and will check and readjust. A note to those who aren't familiar with mechanical (vs hydraulic) valve adjustments: after initial break-in , valves change relatively little provided the valves and heads are made of quality materials. Personally, I'd consider adjusting the Pioneer's valves at 50 and 200ish miles and then see how much they're off at 400-500 miles and then decide the frequency needed.
Reactions: Tflynn
Farmer
Farmer
2,973
17,161
Southern MO
I need to check them.
jawquin
jawquin
299
653
Indiana
Good info. No for me. I'm getting close to 4000 miles and not checked them. Runs better today than the day I brought it home.
Reactions: swsebek
dale5740
dale5740
886
417
mt airy md
how lingoes it take to do it? is it hard? what do u have to do maybe a quick summery and do I have to buy the service Manuel to do it. I have done valve adjustments on my street bikes before prob harder than this is having to re do the timing etc and put thicker and thinner shims in etc pain in the but
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
Give this a read
P700 - Adjusting valves
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
Oh wait @dale5740, don't you have a 1000? Sorry don't know a thing about that!
