P1000 Aftermarket Cage for a 1000-5
JenElio
JenElio
77,268
687,133
Loxahatchee, florida
So im not sure how bad thebdamge is but im just going to throw it out there. Have u thought of strapping/chainning it down and trying to fudge it back the opposite way? Might fix it enough not to bother u so much till u replace it
ABischoff
ABischoff
37
Ohio
Gave this a shot this morning...strapped it to my biggest tree and just yanked it in reverse a few times until it was where it should be. Didn’t take a ton of work. Still need to replace it soon but it’s at least closer than it was.
818267C7 943A 4910 9156 0589B50D85D8
t-bear
t-bear
NE OK
Can you pull your plastics to check the lower 4 ROPS bars to the frame areas? Id take a real GOOD look at those.
I found a couple loose factory bolts at the lower bars (which connect to frame) where they tied into the upper stuff.
Be a shame to find damage to those lower bars IF you do an upper system replacement.
Reactions: Mudwing and Isaiah
