P1000 Air cleaner on pk1000-3
Rockydog
73
165
Canada
Today I learned how hard it is to remove any clean air cleaner. Honda and their darn allen wrench screws. Stripped two heads,got the darn thing off only to find it wasn't that dirty. Contacted honda dealership to find that you don't any cleaner and the price of mew one is 52.00$can. What a job to get at and clean.
Reactions: Mudwing and BWAF
66,871
Hey. Welcome to the club.
Ya, there is a few b**** post about it. Including my own somewhere.
Removing the seat back helps but that's just another step. Still might save you some time.
Thanks.
Reactions: TripleB and Mudwing
208,726
I just get in the cab with the bed raised bend over the seat remove the Allen's then go to the back and remove air filter, but I'm used to working upside down, I'm a plumber! HA!
DDDonkey
That’s how I do it, and you can find the filters cheaper online.
208,726
Thanks guys,but my honda has solid rear window and cab. Just have to do it the harder way. Lol
You have a mechanically inclined 3 year old, that would be the ticket! HA!
Reactions: Mopower58
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
You did tilt the bed right? Use a long extension and blow the screws out with an air hose first.
Reactions: ohanacreek
Rockydog
73
165
Canada
Ya did all that,but a 6-pt.bolt head would have been a lot better. Found that it's just as easy to take whole unit off of intake then try and undo the bolts. Still stripped 2 of the hex head ones. Drilled them out then tapped to a larger bolt. Learning is always a good thing.......maybe.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Yea it's a piss poor set up at best. Wish it just had the snaps like the talon does. At least they realized their error.
Rockydog
73
165
Canada
It may not matter how clean the air filter is. If the government here in Alberta screws around we may not have anywhere to ride other than our own land. Their talking of making all the rest of the forestry into provincial park. So that being said everything from Banff to Jasper will be park.
208,726
No poop?
