air tronic heater
T
Tritonman
41
41
Anyone have any experience with an air tronic style of heater. These get plumbed to your gas or fuel tank. Then you can run your vents from it. Up to 18000 BTU for one of the models. I see that John deere has an option for something similar for the gator. Looks like the best heater setup but they are spendy.
F
farmer700
80
I haven't heard about this kind of heater. Does it run off gas? and burn to cause heat.
So, heat be better then a water heat one for sure. and almost instant.
T
Tritonman
41
41
Yes, they run off your fuel source, essentially like a mini furnace. These are common for bus's and for semi drivers so that don't have to let there truck idle all night. They are several different styles, some just heat the coolant, but I am looking at the air heater. There is a little fuel pump that pumps the fuel and a "glow plug" that lights things up. Quiet and the heat is essentially instant.
67,195
I could see this being a better option. Only factor is you use fuel faster. Unlike the big trucks with the 300 gallon tank. I guess it depends on your riding plans in the snow. If you only do short trips then this may be the way to go as you almost have instant heat. But if you are doing long trips, saving your fuel would be priority.
T
Tritonman
41
41
I think they burn about a quart per hour to two quarts. That would work for my style of riding I could mount it to the ceiling of the 4 person top and run the heat outlet in above my head.
F
farmer700
80
Na, I'll pass for a more free heat source as distance is what I want.
T
Tritonman
41
41
Im looking for both as this would be sweet for when Im ice fishing with the shelter I made for the Pioneer.
67,195
Ya. Now see this as being about the only choice for a ice fisherman.
