P500 Am I missing something
bskerj
15
17
I am getting ready to install a Warn Pioneer 500 Winch. I purchased a sub harness figuring that I could use that for the winch along with 3 other accessories. My problem is that I only see 2 connections on the harness. Can someone enlighten me and tell me if I am missing something ? I installed a winch on my Foreman but I never used a sub harness before. Attached is the harness. Thanks in advance.
bskerj
15
17
Thanks Rustell and Buford....I am glad there was another..it looks like the black ended one plugs into the accessories plug in located in the cab. Can you use one of the 4 for that purpose ? I will probably head over to Amazon and order from the link you sent Rustell
182,377
View attachment 17896 I am getting ready to install a Warn Pioneer 500 Winch. I purchased a sub harness figuring that I could use that for the winch along with 3 other accessories. My problem is that I only see 2 connections on the harness. Can someone enlighten me and tell me if I am missing something ? I installed a winch on my Foreman but I never used a sub harness before. Attached is the harness. Thanks in advance.
I ran my winch leads to the battery/power block.
Seems like a winch would be alot of draw on those small wires alone.
But I'm no electrician either.
bskerj
15
17
Agreed Trigger...the harness is for the switch for the winch that mounts on the dash...thanks
Reactions: Sledge and trigger
bigbore
bigbore
218
269
FWIW:
P500 - Obsessive winch install.
