N
Ok. First the info:
2021 1000-5
Electric accessories:
Honda switch plate with volt meter (came with additional fuse box for OEM accessories)
Honda windshield wiper
Honda SxS Club dual back up lights with factory plug
Honda SxS Club work light switch (uses same factory plug as the back up lights)
Honda SxS Club key on power harness (cigarette lighter plug)
Honda SxS Club small light bar that plugs into the factory harness for use with high beams
TurnPro sequential turn signal kit.
Here is the question. Do I need to run a second battery? All of the accessories are basically short use items (windshield wiper possible exception). I plan on running the 12v key on power harness (cigarette lighter) to a small bus bar to power the switch
back lights for the turn signals and work light switch for the rear lights.
Here is the bus bar I intend to use: https://www.amazon.com/gp/product/B0B7B1SKM9/?tag=sxsweb24-20
And I don't intend to add a wench, large LED light bar, or sound systems. I may add a couple cube lights down the road.
2021 1000-5
