I had over 1000mi as well always perfectEZSteer is best modification I made to my 700. Have over a thousand miles on mine and it still works like a charm. Really makes those multipoint turns easy not to mention no bump steer and less fatigue after all day at the wheel.
As always, peer pressure is alive and well on hondasxs.com! I'm not sure if you've read through the thread on ez steer or not but to make your life easier just know you do not have to remove the dash or the c-clip on the steering column during installation, even though they tell you to in the instructions.Dammit. You guys are going to break me. I'll order the EZ Steer.
That is how I did it. Hood and fender. If I remember right it took right about 3 hours I think? That was with a friends help.
My EzSteer took a lot longer than 3 hours to install mine (guess how many 12 packs and Whisky shots). HOWEVER I had to relocate my heater, hoses, wires, ducting....a real PIA but I would do it again in a heartbeat3 hours.... about one 12 pack.
I was curious if someone would be able to take a pic, or if you know if there is a picture of the ez steer installed under the hood. I am working on my electrical components and was contemplating putting a second battery under the hood, but didn't know if it would interfere with the ez steer when I order one for my own Christmas present. I don't think I will ever put a heater, but I didn't want to move a bunch of stuff when I decide to put the ez steer on. Thanks in advance.Yeah when it becomes a safety issue you gotta do it. I don't know what a broken wrist costs but I bet ez steer is cheaper!
What size battery were you thinking?I was curious if someone would be able to take a pic, or if you know if there is a picture of the ez steer installed under the hood. I am working on my electrical components and was contemplating putting a second battery under the hood, but didn't know if it would interfere with the ez steer when I order one for my own Christmas present. I don't think I will ever put a heater, but I didn't want to move a bunch of stuff when I decide to put the ez steer on. Thanks in advance.
I'm thinking about using the stock yt14 battery and install a new GYZ16 for the starting battery. It sounds like the Canadian models come with the bigger battery from the factory, so I thought I would upgrade. I had a little trouble starting in the cold last year and I think it is due to the size of battery. I am sure I have enough room but I just want to make sure. ThanksWhat size battery were you thinking?
