Shadesmn did you use 2" PVC? Does the intake stick out beyond the rear rollbar? I use a back panel although I could turn the top elbow to face forward.
Yeah i used 2" the whole way. And a reducer at the airbox fits tight if you open the collar up to wiggle it in. It sits pretty flush with the back, if it sticks out its not enough to hit anything. I'll get a better side pic when i get home tonight.
So i guess it sticks out a bit more than i thought, but still not bad. Easily remedied with it turned a different direction the way i did it. And if its staying inside a closed off cab a 45 on top instead of a 90 might even keep it inside..thats mostly why i ran it inside so the whole thing wasnt hindering space on the rack
@JTW i think you'd fit right in with the rest of the dirty minded crowd in my neck of the woods. Always have to be careful of setting up a that's what she said type response.
You could always run it further up the roll bars with some more angled fittings to keep it inside and get it near the top so the noise isn't right next to your head. It wouldn't take much I don't think. Probably like a 22.5 turned toward the front and then it would be almost straight up and down from there.
I also figured if I ended up putting the Honda back panel on I could just leave the bottom center part zipped open and let the snorkel go thru to the back that way. Or if you run a hard plastic panel you'd have to cut a hole for it I guess..
