I ordered a warrior riser and will just do my own from there.I like it.. I was going to do my own but that looks nice and says it has a line-x finish already on it so it would match right up already.
Yes.. I also ordered the prescreen filter.. at $10 don't waste your money on it.. it's literally just two 1/4 inch rings of 2inch pvc with a piece of fine mesh screen glued between. Love the riser but make your own prescreen filter.Did you just order the 2"
Dang it ehart! You just posted my next mod. Hope you don't have to remove the rack to install.
Laid there thinking about it last night, can't do it. I have enough room, even with the toolbox. But with the rails on top of the box, they would hit when I opened it. That sucks...I want a snorkel.
Do you run a back panel? I ran mine inside the cab and up between the seat back and the cage right in the center. If you don't have a panel in the way it works good. I wasn't really snorkeling for crazy deep water, just wanted it up out of the dust a bit and away from possible water in a surprise situation..Laid there thinking about it last night, can't do it. I have enough room, even with the toolbox. But with the rails on top of the box, they would hit when I opened it. That sucks...I want a snorkel.
Yeah mines pretty subtle, which is good cuz they're technically not legal to run here. I can post some pics when i get it back home next week from up north.I have the net on the back. Same here, not going scuba diving but would pull better air...looks bad ass too.
