P500 Another snorkel question
K
KevinP
There is a vent or drain by the oil filter should it be moved up as well as the vent lines
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Yes I extended all vents on mine;) better safe than sorry!:cool:
Reactions: JTW
K
KevinP
That's what I thought cool thx will post pictures when I'm done
kenmo
kenmo
76
85
mayfield, ky
awesome, Ive been waiting for a snorkel kit to come out for these. thanks ehart814
Reactions: ehart814
drfubar
drfubar
TheDonFather
5,889
19,233
Mary's Ridge (Dayton Mtn), TN
7 total which includes the snorkel at least on the 1000. not sure about the 500
Did you just order the 2"
Yes.. I also ordered the prescreen filter.. at $10 don't waste your money on it.. it's literally just two 1/4 inch rings of 2inch pvc with a piece of fine mesh screen glued between. Love the riser but make your own prescreen filter.
Reactions: drfubar
162,466
Dang it ehart! You just posted my next mod. Hope you don't have to remove the rack to install.
Laid there thinking about it last night, can't do it. I have enough room, even with the toolbox. But with the rails on top of the box, they would hit when I opened it. That sucks...I want a snorkel.
Reactions: JTW
Longbrake500
Longbrake500
96
168
Anna Ohio
Glad you said something.. I was going to order this as well not even thinking about it being behind the roll cage. I have the space as well but the box would not open if I had it on. After reading your post I though well I can get some 45's and step it back but that won't work with the rear panel on.
Reactions: trigger and JTW
Shadesmn
Shadesmn
505
959
Ramsey, MN
Do you run a back panel? I ran mine inside the cab and up between the seat back and the cage right in the center. If you don't have a panel in the way it works good. I wasn't really snorkeling for crazy deep water, just wanted it up out of the dust a bit and away from possible water in a surprise situation..
162,466
I have the net on the back. Same here, not going scuba diving but would pull better air...looks bad ass too.
Reactions: JTW
162,466
Keep staring at the pics, wish they gave a side photo. Wondering what would be involved to get them on the inside of the cab.
Modifying it might make the black liner look like crap. Someone needs to buy one and give me some details. ;)
Shadesmn
Shadesmn
505
959
Ramsey, MN
Yeah mines pretty subtle, which is good cuz they're technically not legal to run here. I can post some pics when i get it back home next week from up north.
Reactions: JTW and trigger
Shadesmn
Shadesmn
505
959
Ramsey, MN
Heres a couple pics of mine inside the cab for you @trigger
20161013 151332 20161013 151318
