P1000 Another Wiring Newbie
jemartz1990
17
10
Landisburg, Pa
Purchased a 2020 P1K deluxe back in May. I mounted and wired the Warn Provantage 4500s winch and True Dual Battery Isolator 2 weeks ago.. Simple enough. I have yet to wire in the dual voltmeter that came with it. I was using a fuse splitter to add into the key on power source to the dual voltmeter relay, but after trying numerous combinations the voltmeter is always on or totally off. I can't seem to have it on only when the key is on.
I purchased a Stinger solenoid, bus bars, blue sea fuse block, PBR 6 switch panel, on/off/on switch, and USB port. However, with so much trouble just trying to link the voltmeter in correctly I'm lost on wiring all these other items in. I want an on/off/on switch for my aux power to be on demand and key on.
Does anyone happen to have a setup like this and can share a wiring diagram?
I have seen other wiring diagrams on the forum but there's slight variations that make it confusing for me.
Reactions: TxDoc and Isaiah
67,183
I drew this up last week for someone for the on/off/on stinger control.
Keep in mind, your switch may be different. 2ab569b67d0c59b54ab8713c955a67ce
Reactions: TripleB
jemartz1990
17
10
Landisburg, Pa
Does anyone know how to wire the true dual voltmeter so it's not on all the time?
jemartz1990
17
10
Landisburg, Pa
Use the relay that came with it.
I did use the relay. I got confused because i followed the directions to the letter and it stays on all the time. The only thing it could be I think is the "spare" keyed ignition ground I just grounded it in general. I didn't really understand keyed ignition ground. I thought a ground is a ground
I used the red wire on the relay to an add a circuit fuse tap to the 15amp acc fuse in the factory fuse box, ran the ground wire, and attached the spare keyed ignition ground to that same ground, and ran the other green wire to the voltmeter. Then, I ran the blue and green wires to each side of the true isolator.
TripleB
TripleB
15,618
140,491
Caryville, Tennessee
I did use the relay. I got confused because i followed the directions to the letter and it stays on all the time. The only thing it could be I think is the "spare" keyed ignition ground I just grounded it in general. I didn't really understand keyed ignition ground. I thought a ground is a ground.
Just tape up the extra ground. Im sure that your problem.
jemartz1990
17
10
Landisburg, Pa
Keep in mind, your switch may be different. View attachment 209425
I wired the switch the same as the diagram you drew and it works just as intended. So, thank you for that. However, the switch I have has an upper and lower led. The upper led is for key on, but the led stays on when the key is off and the switch is left in the key on. Any advice on how to get that led to turn off? Or is the a better switch you could recommend swapping it out with?
67,183
Need more info in the switch you used. Can u post a link or wire diagram for it?
Is the bottom one also on by chance?
jemartz1990
17
10
Landisburg, Pa
I used a 7 pin dorman 20amp on/off/on switch from auto zone with top and bottom leds. I used the attached diagram to wire it. The switch looks like the one attached but has a square led on the bottom of the switch also.
Screenshot 20200706 202452 Chrome Screenshot 20200706 202811 Chrome
67,183
Idk.
I cant find that switch.
Did it come with a wire pin layout?
jemartz1990
17
10
Landisburg, Pa
I don't have anything on it. The pin layout was the same as your diagram though.
67,183
Just cause it looks the same does not mean its the same same.
This is the layout I drew for.
20200706 214344
Reactions: TripleB
67,183
Ill explain it. Might help you figure it out.
4, 5, & 6 is the actual switch.
1, 2 & 3 is also a switch but it controls the lights too.
7 is shared ground.
If 1 has power the top lights up.
If 3 has power the bottom lights up.
4, 5, and 6 have nothing to do with the lights, that's why I jump from 5 to 2.
2 then switches the lights. Ffbcc93b8836f7f4b659b1cb192a237b
Reactions: Adam490 and TripleB
jemartz1990
17
10
Landisburg, Pa
Idk.
Here's the switch I have and pin layout. The switch works exactly how I want it to on the diagram you had laid out for me but the top led light for they key on setting does not go out when the key is off. Is there an on off on switch you would recommend for the wiring diagram you sent me? With the diagram of yours I used 1 and 3 have nothing connected to.
Screenshot 20200709 180809 Chrome Screenshot 20200709 181042 Google Screenshot 20200709 181715 Chrome
67,183
You cant use 1 and 3 or light that has constant power will stay on.
60,949
I think this is the same switch you and I fought on my machine. Pretty sure it ended up being that the diagram was wrong and it was actually reverse of what was printed.
