L2R
Understanding women Vol. 1
I just moved a work shop about 35' that is in the back yard.
I there is now a panel box with a 110 and a 220 breaker hanging in the wind and need to move it.
I am planning to trench a ditch, install a junction box and make the connections and re-wire the shop.
Then hire an electrician to inspect it and throw the switch.
Looking for some advice:
is 24" deep enough to trench for the lines?
can I run 1 piece of conduit in the ground and run all the wires through it?
what size wire would you recommend? the current location of the panel box is about 100-125 feet from the main breaker in the garage.
can the junction box be underground. there is one now above ground (not directly connected to what I am working on) and no idea why it would be there in the way of mowing so.....
thanks in advance for any advice.
