highpocket74
Give some feedback if you P1000 owners would be interested in a shifter plate similar to the one I've designed for Talon.
The overall design would be similar to my Talon plate, with the exception of the park location. Looking at pics of the P1000 shifter subframe I believe I can make this design work within the available space. Of course since the 4X4 shifter is included on the same plate, I'd have to improve that design also.
Benefits of this plate as described for my Talon plate:
Features and Benefits (Talon):
- Designed and manufactured in the USA, first and foremost!!
- Precision CNC laser cut from ¼” 5052 aluminum for perfect fit and function
- Straight back shift into Low rather than awkward OEM hook motion
- Quicker, no look Reverse-High shifts with right side channel and stops
- Lever notches prevent accidental bump shifts and transmission damage
- Narrow shift channels improve shift accuracy and reduced heat intrusion with 5% less open area than OEM.
- Durable textured powder coat finish
- Rigid aluminum improves shift feel over OEM plastic
- Uses OEM mounting location and hardware
- Easy 15 minute bolt-on install with 10mm socket and small punch to release plastic rivets (Talon specific)
