P1000 Any thoughts?
dukeANhammer
dukeANhammer
60
147
check and see if anyone in your area does plastic welding.i have a hot gas plastic welder at work and it does a great job.i've welded all kinds of things with it.
Really like to see some pics of that plastic wishing you do. I just tried the other day with a soldering iron and got mixed results. I imagine it would work well if you had the correct filler to use.
rickoshea
yeah,a hot gas plastic welder is a whole different animal,although it does come with a small hand held iron to smooth out the seams.it's literally the same thing/size as a welder.no pics,i'm off work till after summer at least..
Isaiah
Isaiah
2,191
6,964
Altamont TN
Might be time for an exoskeleton?
I'm really thinking about one;) I got my freind to build my some tree kickers he hasn't had time to build the mounting brackets thought:(
IMG 20200327 210127Imagejpeg 0
G
golfer1
117
269
Alabama
You might try some abs adhesive like plumbers use on plastic pipe.
Reactions: Isaiah
Mopower58
Mopower58
Unburdened by what has been!
88,248
755,578
Crystal Springs,Ms.
