P1000 Any thoughts?
Isaiah
Isaiah
2,191
6,964
Altamont TN
I busted my fender I was wondering if there was any way I could fix it? It came on the pioneer when I bought it really don't want to buy a new one.
Thanks in advance
20200409 16085220200409 160913
116,567
i cracked mine at the take over a few yrs back and about the same spot. I just put the push pin back in to secure it and used some JB weld on the crack to keep it firm, put a little flat black paint on it and called it good. haven't had a problem since
Isaiah
Isaiah
2,191
6,964
Altamont TN
i cracked mine at the take over a few yrs back and about the same spot. I just put the push pin back in and used one JB weld on the crack to keep it firm, put a little flat black paint on it and called it good.
I put a pin back on it just wasn't sure what to do for it to stay in place:) Thanks for the help;)
Ultrasonic1
Ultrasonic1
206
766
Nomadic
3M and a couple other auto body supply companies make 2 part epoxies that work great. But that wouldn’t be worth it to buy it just for that. It’d cost more than replacing it. Have any friends that work in a collision shop?
Isaiah
Isaiah
2,191
6,964
Altamont TN
What kind of JB weld? I know they have a lot of different kinds
Isaiah
Isaiah
2,191
6,964
Altamont TN
No🙁
Reactions: BWAF
116,567
The standard stuff will be just fine. When u mix it just be like a Picasso and smooth it across the crack. It will cure just fine and with your push pin In it, you’ll be good. Work smarter not harder ;)
Ultrasonic1
Ultrasonic1
206
766
Nomadic
Can you access the back side easily? If so, score up the plastic with some sandpaper so the JB weld will adhere a little better, and use something like emory cloth or something mesh on the backside. That will reinforce it. More shear strength = less likely to break again.
Isaiah
Isaiah
2,191
6,964
Altamont TN
Yes I can get back there good. Thanks for the information;)
Reactions: Ultrasonic1
