The Low range engagement issue is usually a driver training issue. If possible don't use Low until it's warmed up, always make sure the display shows L not - (dash). Shifting at a SLOW roll helps the shift dogs align, so does having your foot off the brake.Well that sucks. Ive heard that getting an r2c filter solves 99 percent of the intake problems. Whats the best remedy for gear engagement? Different oil or shifter gate?
An aftermarket plate is not absolutely necessary with proper adjustment. But if you want a good, I have them.
I should have silver plates available again next week sometime. We've been Honda people for most of our lives, until the RZR came out. My father-in-law was mostly disappointed with his Talon shifting into Low from day one. That was one of the driving forces behind designing a better shifter plate. Besides that I just hated the way the OEM plate shifted because you HAD to look at it to shift properly. But the trick was figuring out how to adjust the shifter cable and tune it to where it shifts like you think a Honda should. I haven't ground low gear since we fine tuned the cable adjustment.
As a diehard Honda fan you should know that historically Honda only addresses issues of new colors and graphics. They build the same machines for decades with no mechanical changes.
I would not go to the RC2, see photo. The cheapest way is to put a snorkel on with a filter. The best way is to put a prefilter on like the S&B or KWT. I went with KWT.Well that sucks. Ive heard that getting an r2c filter solves 99 percent of the intake problems. Whats the best remedy for gear engagement? Different oil or shifter gate?
Ive never met anyone disappointed with the r2c performance. That picture looks like it wasn't sealed properly.My r2c has never left my air box looking like that,, yea I have not ran in the desert but ate lots of dust on gravel/dirt roads behind other UTVs. I check it often and not one spec of dust in the box, I would bet that dude did not get the lid snapped down right and did not put grease around the sealing surface. Just for safety I keep the intake tubes covered with one layer of the uni green foam that is oiled. I have checked that foam just to see if anything got past the r2c and nothing found.
