P700 Anyone running a HMF Swamp Series on a 700-4
Texguy02
6
Southeast TX
Wondering if anyone has a HMF Swamp Series on a 700-4 here. Want one to get with the Dobeck for a little extra thump but do not want a loud exhaust.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I don't have one but numerous people have said it is the quietest aftermarket pipe. I have a yoshimura, which is probably the loudest aftermarket pipe! So don't get that one!
I would love to hear your impression of the pipe and tuner together once you install them. Keep us updated. Welcome to the club!
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
Hi Tex, Welcome.
I don't have the answer either and I'll be watching this thread. I want quiet without compromising power.
Reactions: Farmer
Simpleman
Simpleman
57
29
Yuba City, California
Hey fellas! I'm running the HMF Swamp exhaust pipe and I can say that it perfect! Slight gain in torque and hp with minimal increase in decibels. It has a bit more bass in the exhaust note. They also make a silencer that goes into the muffler for extra sound reduction. Perfect for hunting or to those who want the quiet... I'd say with the extra silencer it quieter than stock. Just my opinion. Do not get the XL Swamp version as plainly stated on their website it is Extra Loud....
Texguy02
6
Southeast TX
Thanks for the response, really appreciate that.
You running the Silencer? Any other mods done on your part? Example filter or programmer?
Simpleman
Simpleman
57
29
Yes I have a K&N intake filter with the prescreen cover and I have snorkeled the machine with a "ram air" design. It has helped the machine out at high elevation. I've noticed better throttle response and a overall power gain. I haven't purchased the Dobeck programmer yet....Yes I'm running the extra silencer right now... I haven't taken it out since hunting season.... works very well. There are quite a few snorkel designs out there...some people like them and have experienced power gains while others have not. I did it for location of cool CLEAN air. Search the posts for ram air intake snorkel and you can see the build and conversations that ensued. Let us know if ya get a programmer and how well it works!
Texguy02
6
Southeast TX
Simpleman- is your Pioneer a 14 or 15? Called to order the pipe and they said they dont have one for the '15 model yet. Cant imagine the 14-15 changing the exhaust piping that much
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I believe @Simpleman has a '14. The only difference I could see there being is the '15 and up have an O2 sensor. So if you can drill a hole and weld in a bung you should be good to go!
Reactions: Simpleman
SuperYeti
SuperYeti
220
375
Vancouver, BC
The '15 also has a catalytic converter doesn't it?
tlandry
New Iberia, La
How will the catalytic converter effect it? I was thinking about getting the exhaust and bypassing the O2 sensor or adding the bung either way.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I would never do such a thing but I had a friend who removed the cat from his truck. All it did was trigger the check engine light but the truck ran fine. What I don't know is if triggering the check engine light on the pioneer would put it in limp mode or not, or if removing the CAT would even trigger it for sure. Is the O2 sensor before or after the cat? If it's before (and there are no sensors after) then you should be fine. But don't ditch the O2 sensor, you're engine needs that data to run correctly.
tlandry
New Iberia, La
Not ditching the O2 sensor. The programmer I purchased (dobeck gen 4) came with a module to bypass it. My guess is it just feeds the ECU voltages to make it think it is reading the sensor.
I also know someone who removed a Cat from there their P700-4. No ill effects at all.
Sent from my iPhone 10s
Reactions: Tflynn
Gator
Gator
2,475
10,396
Louisiana
Removing the cat should not result in any performance reduction.
Might or might not increase performance. Might or might not affect emissions. Might or might not be legal in all states.
Reactions: Tflynn
It should reduce heat under he passenger floor. Those cats stay hot for hours after all the pipes have cooled.
How about a weight reduction? Does that count? :)
