P500 Anyone running with these mirrors
rocmar
rocmar
4,741
5,776
4 CORNERS
41 6qzZhmL SY400
any comments
Yep, and I love them.
Reactions: trigger
I'm using them on my P1000 and they don't work as good as the Siezmik mirrors. They are way better priced though.
you don't want those mirrors if you ride where limbs will smack it. The Siezmik will be better in tight trails. That may not be an issue for you.
rocmar
rocmar
4,741
5,776
4 CORNERS
Thanks Joey
mostly desert ride
Oh..kool
didn't know you had
them...been researching
them for a while
I was thinking I had them when we rode, perhaps not. They are very adjustable in multiple directions. They easily break away with no damage if you forget to pull them in on tight trails, and they sure make backing up easy on my neck. The rear view mirror is good for keeping an eye on riders behind you, but not much for backing up. I highly recommend these mirrors Rocmar.
rocmar
rocmar
4,741
5,776
4 CORNERS
Yeah...
both items..went from cart
to gimme. ..your $ ...& they
will be in the mail...haha
Reactions: Montecresto
I ride trails that go on for miles at a time with brush raking the sides. I usually just pull them in then. Occassionaly I forget to pull them in, but the brush just pushes them in then. Not meant to be dismissive of the Siezmik whatsoever though.
The Siezmik are good for the 60" vehicles I guess because I can easily push them out and they pop back into the preset position automatically.
If you don't ride in a lot of brush and you can reach your passenger side mirror easily, those mirrors you posted will work just fine. I still use them and I don't plan on upgrading anytime soon just because of the cost of those high dollar Siezmik mirrors
Sent from my iPhone 10s
rocmar
rocmar
4,741
5,776
4 CORNERS
Yeah crazy spendy
Agreed, if I'm riding alone, it's easy on the P-5 to reach over and pull the mirror in or adjust it if need be. I can see that that would be a bit difficult on the 60" machines.
ghost
ghost
993
1,873
BC
I just put one of these on my P-1000 and I really like it so far.
Amazon.com: ATV Tek (UTVMIRCTR) Clearview UTV Center Mirror: Automotive
They dont really advertise it but there is a memory feature to them. There is a macro adjustment at the pivot closest to the rollbar that clicks into place. And a micro adjustment where the arm attaches to the mirror.
So - if you're going to bump something, you can click the mirror in and quickly click back into position later. Not sure what happens if you hit an obstacle - it might throw the micro adjustment and the macro. But It will move out of the way.
Some mirrors are sold as a set - these come individually. I didn't realize that when I ordered so I was a little disappointed opening the package. But now that I've used it - well worth the money.
Reactions: trigger
ghost
ghost
993
1,873
BC
You can set it horizontal or vertical.
Horizontal Veritical
Click it out of the way. I bumped it out of the way with my hand and it clicked back into position where I had it. If you wack the mirror with a branch you probably have to re - adjust the micro.
Click
Micro adjustment.
IMG 2710 IMG 2707 Lapdog
Seg
Seg
189
322
Notre-Dame de la Salette, Qc, Canada
View attachment 15089 View attachment 15091
Micro adjustment.
View attachment 15081 View attachment 15084 View attachment 15090
I've just received my order from Amazon and will install this weekend. Looks like it will do the trick!
