P1000 Anyone with a hard mid panel
322,690
Just wondering if I could get a couple rough estimates on the mid panel. I'm looking to see if there is room to cut 5 inches from hopefully the top of the panel. Anyone have one that's not installed?
272,137
I will check mine when I pick it up hopefully tomorrow. 5" would be awfully close to the glass at the top corners, just from memory.
Reactions: CumminsPusher
322,690
Ok awesome thank you @JACKAL. Received a call and on a broken one that I could get cheap so I'm considering
Reactions: Eltobgi and sharp
322,690
6 inches pretty clear?
Reactions: dotman1
W
wyodlr
147
209
Cody Wyoming
Just looked at it again there is no way you could cut over 1 1/2 " off it due to how it mounts ,it extends above the rollcage to hit the roof
322,690
Damn ok exactly what I was looking for thank you I appreciate it.
272,137
I didn't get a call to pick mine up so sorry I'm no help but sounds like you got the info needed, so that's good. Hope it works out for you.
322,690
I appreciate you trying to help I know had it been close you would've. Doesn't sound like it'll work easily though.
272,137
If you are making rear doors, I would forego the mid panel and make a rear window lift gate from tail gate to rops, like on a Jeep Wrangler
322,690
That's a great idea may just do that Would actually be easier then building a frame for the center. Thanks for that! I was just just pondering idea of the mid because I found a broken one for 200.
ghost
ghost
993
1,873
BC
You might be able to do it if come up with some other mounting hardware.
The second measurement shows how close the lower dip in the roof would come to the window.
Probably not something I would try but I'm posting pics so the mighty CP can decide for himself. LOL
IMG 3431 IMG 3432 IMG 3435 IMG 3436
322,690
Great photos thanks Ghost Actually pretty close, tight on the sides.
T
taylorman
167
97
Lafayette La
So what front windshield and doors do you run with the rear panel? I have the full glass windshield, hard roof and soft doors. Thinking about getting a rear hard panel. How's the dust with the rear panel?
322,690
@ghost I think @taylorman was referring this question to you.
Reactions: ghost
ghost
ghost
993
1,873
BC
I've got glass windshield and hard roof. Just the stock half doors.
I ran with that setup for a while and it got very dusty. After I added the hard mid-panel (they call it rear panel) the dust was drastically reduced. There will always be some dust but the mid panel really helped. I'm guessing it would be the same with the soft doors you have - the concept is the same - a low pressure system behind windshield sucks dust. The bed area / rear passengers are not as lucky as the front passengers - there is still low pressure behind the mid panel..
