Articulating Hitch
Buckaroo
Buckaroo
29
72
Central Ohio
I am looking for a light duty articulating hitch for my 700 that would rotate on all 3 axis'. Thinking about hauling firewood utility trailer through the woods and over hills - want to help avoid binding, bending and roll over. There are some good (but expensive) heavy duty options available like Lock N Roll but I only need one good to 3500 lbs or less. Looking to purchase or DIY fabricate. Ideas?
Reactions: Backwoods and TxDoc
5,429
24,931
The motorcycle guys use a standard u-joint between the receiver and trailer tongue.
TxDoc
TxDoc
2,245
7,605
TEXAS 🇨🇱
photos.app.goo.gl
NewHere2
NewHere2
Village Idiot In Training
41,933
345,444
High Plains of SD
Sent from my motorola edge plus 2023 using Tapatalk
$60 in materials and 1/2 hour on the welder. The rest is Liability !
272,157
Why not use the standard pintel style hitch? Commonly available, inexpensive, and works. The example shown is way over weight needed but an example of how it can flex.
Screenshot 20231225 131907 Amazon Shopping
Screenshot 20231225 131928 Amazon Shopping
DRZRon1
DRZRon1
1,207
3,901
PA
making an engineering project out of it, need to be careful, I have seen many sxs's on the roof and side from hauling stuff in a trailer - things are so freaking light - need to be super careful going down the slightest of grades
Buckaroo
Buckaroo
29
72
Central Ohio
Buckaroo
Buckaroo
29
72
Central Ohio
I can see this happening which is why I wanted the articulating hitch.
Prntckt
Prntckt
1,093
7,631
Altoona, WI
  1. Talon X4
At some point I plan to build an overlanding trailer. These two DIY articulating hitches were some of the info I found during the online research
5,429
24,931
I saw this one and liked it. Got the welding capability but it looked to me like machining required that I do not have equpment for. Will look at it again.
His list of the tools needed is very basic. Since you can weld, you'll probably have what you need.
Buckaroo
Buckaroo
29
72
Central Ohio
I spent some time with the Tventuring Under $50 DIY thread today.
What a great design and write up! It is do-able for me although my MIG welder is only 140 vs his suggested 180 amp. If I have to, I could dust off the old Lincoln AC/DC Tombstone stick welder and see if that still works. I tallied up all the parts I would need from his material list (again, very nicely done) and now, 10+ years later, it is about $130 vs his original less than $50 but still way cheaper than the ready made options everyone identified.
Thank you all for your suggestions and comments. I do not have immediate plans to pull the trigger on this project but hope to by early spring. Will post back with my results.
Mopower58
Mopower58
Unburdened by what has been!
79,849
709,077
Crystal Springs,Ms.
How is this better than a pintle hitch? When I was in the military every vehicle was equipped with one.
Reactions: TxDoc and Smitty335
