P1000 Auxiliary lights with back up alarm harness??
winnscollision
winnscollision
92
51
Saluda SC
Wondering if the back up alarm wiring harness will work with the auxiliary led lights? Relays, wire size, fuse size, etc. able to pull the power required for the lights, or is it just for the little buzzer?? If so, what's the best way to wire up a back up light that is automatic when put in reverse?
64,906
it will work to run a relay.
Otherwise see the other post.
