P1000 Avoiding water in the air intake.
Alaska350
Alaska350
96
233
Anchorage, AK
So I do not have water anywhere its not supposed to be and I would like to keep it that way. After having a conversation with the dealership service guy it is clear some precautions and modifications are required to keep it that way. I live in Alaska where crossing creeks while riding is normal protocol and cant really be avoided.
I was told the high intake under the hood is not the only spot I need to worry about water getting in which is surprising to me.....apparently there is connection under the seat that water can get in when water gets over the floor boards. I plan on removing the rubber boot and sealing it up with RTV when reinstalling it.
Is there any other places I need to look at?
Is the filter box above the motor 100% sealed?
I saw somewhere someone installed a drain plug at the low point of the intake tube....thoughts?
Sorry I always have so many questions lol I am still new to the Pioneer idea and learning as I go. Thanks in advance!
Ohio4x4
Ohio4x4
I brought the dishwasher
1,528
15,413
Ohio
I installed a extended vent line kit as one of the first things I did before I did my first ride. :)
A quick test for leaks is with the engine running cover the intake and choke the engine out. It should hold some vacuum if all is tight. I put a bag over the snorkel when washing and usually forget to take it off when restarting. It's kind of a dumbass self test that I've wound up preforming more times than I can count.
60,330
Did that on the Talon yesterday... lol
Alaska350
Alaska350
96
233
Anchorage, AK
Just tried that with a piece if cardboard… immediately died like two seconds so I guess the rubber boots that join the connections are sealed tight.
Ohio4x4
Ohio4x4
1,528
15,413
Ohio
If you're concerned this is the easiest snorkel. I got the measurements and parts list from @Adam490 short bus build. I liked being able to see where it breathes because I'm a f***in idiot and have drowned every other off road toy I've had.
300231E5 366C 4606 9482 F1F83E6D24D8
Russ989
Russ989
22,642
147,257
5A447500 8431 4994 B617 CA60718DAC07
PJon
PJon
792
3,214
Arizona
Is there any concern for water getting into anything other then the front under the hood? Filter box? Rubber boots at the connections?
Take your front seat out when washing your machine. The water will get in around the base and pretty soon it will weigh 80 pounds. I think Honda puts check valves in the bottom of the seat so that the water goes in easily, but never comes out. This could be a major problem for those in colder climates unless you enjoy sitting on ice cubes.
P1K5Dave
P1K5Dave
2,244
8,419
Petoskey, MI
I'd like to know what he's talking about here, other than the vent lines (which you've already taken care of.)
I do wonder sometimes about the entire length of the intake tube that runs from front to back. There are joints in it (do they have rubber seals?)
I did the choke-off test inadvertently myself, having covered my intake while doing some wiring and forgetting about it.
WagginTail
WagginTail
1,577
5,827
SC
Yep. I have water in mine. I drilled bigger drain holes in my 700 seat. I need to do that to this one
Reactions: ChadD and Backwoods
Bayouownbeer
Bayouownbeer
797
1,119
Chauvin LA
Send me PM for 5% off eBay prices. The 5% is applied with direct payment using PayPal, Venmo, cash app or Facebook pay. This is the kit thousands of members have used. Includes everything needed to extend all 6 vents with black tubing. No sourcing out parts or multiple trips to the hardware. This includes first class USPS shipping. Instructions and tracking will be emailed. For faster shipping please Inquire it’s $3 extra
Screen shot Reviews on my page in the feed
https://m.facebook.com/Hondapioneer1000seatheatsolutions/
Vent extension kit without filters recommended for 5 seater. Filters not needed your preference. Simple hour install. Great piece of mind knowing your covered.
“The Original” Honda Pioneer 1000/700/500 & Talon Vent Ext. Kit Without filters | eBay
With filters recommended for 3 seater pioneers and the Talon unless you drill three 1/4” holes to put the ends of the tubing into. If you don’t heavy mud you can use the kit without filters and simply turn the ends down 90 degrees.
“The Original” Honda Pioneer 1000/700/500 & Talon Vent Ext. Kit. With filters | eBay
Both heat shields and vent kits package without filters
Honda Pioneer 1000-5&3 Heat Shield's 1&2 + Vent Extension Package Without Filter | eBay
With filters
Honda Pioneer 1000-5&3 Heat Shield's 1&2 + Vent Extension Package With Filters | eBay
Just heat shields. This material is construction grade material very thick 5/16” and durable. Fire class 1 rating
Honda Pioneer 1000-5 & 3 Seat heat Shield Part 1 and part 2 | eBay
