T
So, I'm installing a Axon 45S on my 1000-5 LE. There are a few modifications that need to be made, come on in and follow along or give me advice along the way...
1. Fairlead from the backside
2. Fairlead from the front
3. Whoops, we have a clearance issue...with the spool release on the passenger side, this is the spot where it conflicts with the front bash plate.
4. Closeup. Winch gets marked up trying to fit it. I would suggest painter's tape on all contact surfaces to avoid this if you care.
5. I flipped the winch to have the spool on the driver side. Does anyone know if this is a problem for the winch or its operation? The winch rope is coming off the top.
I'll update as I get time to keep working.
UPDATE!
I spoke with Warn's technical support team this morning. They are going to send me some updated information for mounting the AXON in the 1000-5 LE.
BUT, they were very clear that you should not "respool" the rope and switch the power input. Their reasoning is that when you do this you will be working against the internal brake. Also, to keep this in perspective, the "bottom" of the winch is the mounting bolt side. The rope must be spooled so it comes from the "bottom/mounting bolt" side of the winch--no matter if the winch is right side up or mounted upside down.
UPDATE!
