P1000 Axon Winch Install on 1000-5 LE...it's a journey UPDATE 1 in OP
thirdparty
68
96
USA
So, I'm installing a Axon 45S on my 1000-5 LE. There are a few modifications that need to be made, come on in and follow along or give me advice along the way...
1. Fairlead from the backside
IMG 20190916 203753
2. Fairlead from the front
IMG 20190916 203626
3. Whoops, we have a clearance issue...with the spool release on the passenger side, this is the spot where it conflicts with the front bash plate.
IMG 20190916 210936
4. Closeup. Winch gets marked up trying to fit it. I would suggest painter's tape on all contact surfaces to avoid this if you care.
IMG 20190916 212303
5. I flipped the winch to have the spool on the driver side. Does anyone know if this is a problem for the winch or its operation? The winch rope is coming off the top.
IMG 20190916 212843
I'll update as I get time to keep working.
UPDATE!
I spoke with Warn's technical support team this morning. They are going to send me some updated information for mounting the AXON in the 1000-5 LE.
BUT, they were very clear that you should not "respool" the rope and switch the power input. Their reasoning is that when you do this you will be working against the internal brake. Also, to keep this in perspective, the "bottom" of the winch is the mounting bolt side. The rope must be spooled so it comes from the "bottom/mounting bolt" side of the winch--no matter if the winch is right side up or mounted upside down.
Reactions: Plumber32 and BWAF
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
Sweet I want one of them on rear !
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
You want the rope coming off the bottom. Just spool it out and run it in the other way. You'll have to reverse the wires so that IN and OUT are correct on the switch.
sharp
sharp
3,757
14,955
Tennessee
Exactly. The winch will be fine mounted upside down, that is the way warn recommends it to be mounted for the p1k
thirdparty
68
96
USA
So just switch the wires at the winch connection?
Reactions: ohanacreek
thirdparty
68
96
USA
I put this in the OP as well:
UPDATE!
thirdparty
68
96
USA
UPDATE!
Here are some shots from the Warn installation info showing the clearance that needs to be cut for the Axon 45S full drum and how the short drum version fits without cuts:
Axon 45S Full drum clearance:
Warn clearance
Axon short drum appears to fit! The additional Warn info I received says "minimal griding, if at all" to get the short drum to fit.
Warn short drum
Reactions: sharp and Plumber32
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
UPDATE!
If you mount the winch upside down but also turn it 180degrees aka end for end. It will still pull off the spool the same. The release will be on the opposite side.
I did this with my vrx 45s
I was under the impression that the brake works the same in either direction. Perhaps the axion is different.
If you switch end for end no wiring change is needed.
Reactions: sharp
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Fwiw I have run several in reverse and never had an issue...brake worked just fine.
Reactions: sharp
RedRiverRider
5
Texas
UPDATE!
I heard you needed a second battery to use a winch on the 1000-5. Something about the clutch slipping, is this true?
thirdparty
68
96
USA
I just got mine installed and working, so I don't have enough use in it yet to know. I am planning on adding a second battery in the near future.
