Well that didn't work out. The Harness #08Z02-HL3-A00 must be wrong. I hooked the new harness black connector to 12v socket just fine. The green connector fits nothing in that area. I would think it was suppose to connect to the M/T A/T switch since it is now not hot. This is what it said to do.... First remove the "hood" and look at the firewall. You have to unplug the black plug from the back of the power socket (cigarette lighter plug) and the green plug that's in the center (just back trace the wire). Then plug the black connector of the new harness onto the back of the power socket and the green to the green connector you just unplugged the old harness from. I couldn't get the plastic anchor to let me remove the old wiring, so it's still in there. The important things to note are the new wires sticking out. The white with black stripe is 12 VDC + (two of them) and the green is 12 VDC - (one male plug). Attach your new devices to the harness for key switched power. Be careful total draw doesn't exceed 10 amps or you'll blow a fuse. If you up-size the fuse, you'll melt wires. Relays are your friends.
