P500 Back windows = better dust control?
Bushbaby
Bushbaby
67
186
Elliot Lake Ontario, Canada
I've found that going along dry gravel/forestry roads at speed :rolleyes: I get a huge amount of dust coming in. It's not as bad when on tight trails at lower speeds. I can control it a bit by raising my windshield (Honda OEM) as far as it will go so the wind comes in and breaks the vacuum effect that sucks the dust in behind you. At least I think that's what happens. Does installing a rear window help at all or is it a waste of money?
G
GreenBush
40
57
The Motor City !!
Which rear panel,errrr, rear window, gets the thumbs-up from you guys ? I would like to install one too...
Bushbaby
Bushbaby
67
186
I've ordered an Octane Dust Stopper Rear Mesh which should arrive this week. It's half the cost of the OEM vinyl rear window and it may be a waste of money but I'll report back after I try it out.
Reactions: GreenBush
G
GreenBush
40
57
The Motor City !!
I'm looking around right now and I see Tusk offers one.... Under $70 shipped...not too bad..
Mudder
Mudder
NTC Ambassador of Walls
11,650
87,930
Like the zipper flap on OEM, don’t know if others have it.
JCart
JCart
895
2,021
Kamloops, BC Canada.
I made a rear panel from 3mm thick UHMW along with Lexan roof and sealed behind the seat with truckers synthetic tarp. Works as good as can be expected, although it does keep the heat from engine in. So I also installed a small fan and 3” aluminum tubing for water craft venting under the seat to blow hot air out the rear of the machine, with manual switch works great. It just never ends bahahahaa :)
