P1000 Base tire performance?
Vikes79
Vikes79
SKOL!
11,709
113,612
South Dakota
  2. Talon X4 LV
How well do the stock factory tires perform in snow?
I will be using my P1K5 for ice fishing this winter and I’m a bit worried about the tire performance on ice and deep snow based on some driving I’ve done in sand.
I know I could go tracks but would prefer not doing so.
I had GBC dirt tamers on my Ranger....they were pretty good for ice fishing plus plowing snow.
Just trying to gauge if I should replace now or let the money tree grow a bit. Still have to get side doors and a heater this fall.
Reactions: Plumber32 and BWAF
208,726
I would think the stock tires would do fine, I never had a complaint about traction, I kept busting the 4 ply front tires & 8 ply tires. If you do buy different tires, get 8 ply's and larger tires for the front, think there's some guys doing that on the forum with stock rims????
Reactions: X4Dice and BWAF
X4Dice
X4Dice
87
130
USA
They actually ran good in everything. (Never ran sand) I got 1200 miles on them before I changed. People complain that they were terrible but I used them two seasons with snow. Most of the time I was loaded with wood or something else.
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
It depends if it's a deluxe model or base model. The base model had better tires they are 6 ply.
Reactions: BWAF
208,726
GBC Motorsports
The big horns and dirt tamers are pretty darn close in design. Both look badass on any rig.
I've got a set of ITP Black Waters that I really like on the trails but they are rough riding on pavement at low speed and don't wear well on pavement. Probably the best trail tire I've had.
Reactions: BWAF and Vikes79
Vikes79
Vikes79
SKOL!
11,709
113,612
South Dakota
  2. Talon X4 LV
I’ve heard good things about them. Have you had them out in below 0 weather?
I’ve read on more than tire that cold weather really shortens the side wall life of the tire ( like bogger tires).
Reactions: BWAF
Vikes79
Vikes79
SKOL!
11,709
113,612
South Dakota
  2. Talon X4 LV
I’d estimate that with auger, 20lb propane cylinder plus misc gear I’d have at most 200 lbs of gear plus a couple hundred lb sled in tow.
Reactions: BWAF
208,726
I don't know about the below 0 wear on tires, in my life time so far we've only had two weeks solid below 0. My balls didn't come down till late spring! HA! And we had a 24 inch frost line, our usual is 10 to 12 inches. And how a bout an invite for ice fishing, I've always wanted to do that! And I have always been a Viking fan!
Vikes79
Vikes79
SKOL!
11,709
113,612
South Dakota
  2. Talon X4 LV
Deal! If your ever up my way send me a IM!
We bury all our utilities at 4’ minimum. Some years that’s barely enough.
SD isn’t even as cold as our neighbors to the north!
dilligaff82
157
315
New Hampshire
Ran mine for two full New Hampshire winters with no complaints.
Reactions: BWAF
