P700 Battery Cables
mnmgri4
mnmgri4
12
16
Green Bay
I am thinking of placing a full size deep cycle battery under the driver seat of my P700-2. Are the original battery cables long enough to move from the passenger side to the driver side or will they need to be extended?
Thanks
Mudwing
Mudwing
36,959
306,672
The Mud holes
92EFE1A3 EE9D 4C60 8C78 3EBF19B3FF00
I just checked it out and I’m gonna say you have to extend or replace with longer cables.
Reactions: Russ989
mnmgri4
mnmgri4
12
16
Green Bay
That is what I thought, thanks. I am not anywhere close to my machine to look for myself.
Reactions: Mudwing
Mudwing
Mudwing
36,959
306,672
The Mud holes
No problem. I couldn’t grab a pic of the ground but it connects to the passenger side of the engine and looks like maybe two feet long.
Reactions: Russ989
KyleC
KyleC
102
155
Pittsburgh, PA
Why not just leave the stock battery alone, and install an isolater for a dual battery setup? Easy peesy. Mudwing is correct, the ground wire is probably 2' or less long, and connects to the engine under the passenger seat. The positive is probably 6-8" long, ran directly to the relay(?).
Reactions: Russ989 and Mudwing
