P500 Battery Charger recommendation?
Mudder
Mudder
NTC Ambassador of Walls
11,692
88,500
Need to buy a 12 volt microprocessor battery charger for use with UTV as well as a marine deep cycle batteries. Saw the a CTEK and NOCO smart charger reviews. Like to stay under $100. Any recommendations?
rocmar
rocmar
4,741
5,776
4 CORNERS
I know a slower charge
is...better for the battery.
I use .75 amp $10 trickle
charger...from Walmart.
Hard wired to p5...in
winter...plug it in the wall.
sounds like your lookin for
bigger one
Mudder
Mudder
11,692
88,500
Got a CTEK MUS 4.3. 8 step microprocessor functions. Selectable for Atv, auto, marine and AGM batteries. Comes standard on Corvettes and $$$ high end cars. Will see how it does on old Atv batteries. Also good for trickle charge use.
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
3,132
21,390
Route 66 Oklahoma
I use a Battery Tender Plus. I have had it for about 5 years. I originally purchased it because it was the most popular charger on a car forum I am on, for AGM type batterys. It came with a "quick disconnect pigtail" that I have mounted on my Pioneer battery, and it just takes a few seconds to plug in and unplug. I move it back and forth between the Pioneer and a car that I do not drive very often. Works great.
I have no experience with it, and marine batterys. Amazon.com: Battery Tender Plus 021-0128, 1.25 Amp Battery Charger is a Smart Charger, it will Fully Charge and Maintain a Battery at Proper Storage Voltage without the Damaging Effects Caused by Trickle Chargers: Automotive
rocmar
rocmar
4,741
5,776
4 CORNERS
Yeah..
big chargers not good for battery
all the time...slow charge is best
...mostly with smaller size batteries
for $10 a pop...
you can dangle one off everything
that needs it...
everybody got there own deal
182,443
I use these on my truck and P5, the price is right and they won't harm your battery.
Installed the socket, so now I don't have to keep removing the battery cover, just plug in. 0000 battery tender junior charger mcssBattery socket
Mudder
Mudder
11,692
88,500
The CTEK 4.3. charger is working great so far . It reconditioned and brought back an old lawn tractor battery in 24 hrs. that would not charge with a basic charger. Hopefully a 3 yr old Atv battery will come to life by tomorrow. Interesting high tech stuff for deep cycle, desulfurization and the pulse trickle charge feature. Came with both clamp and eyelet connectors on quick connect pigtails.
IMG 3862 IMG 3863
rocmar
rocmar
4,741
5,776
4 CORNERS
View attachment 40137 View attachment 40138
3 yr old atv/ utv...battery...
nothing but a problem. ...
I'd get a new battery
IMO
rocmar
rocmar
4,741
5,776
4 CORNERS
Lots of threads...about chargers
....& batteries. .with interesting
information. ..& knowledge
rocmar
rocmar
4,741
5,776
4 CORNERS
Wat was the $.....
Mudder
Mudder
11,692
88,500
Yep, the old battery is from a 97 Polaris just sitting in the barn, a good test of the charger. $69 online, $89 at local auto store. Have 9 batteries to keep up with.
Reactions: rocmar and trigger
rocmar
rocmar
4,741
5,776
4 CORNERS
Kool....
my neighbors barn...burnt down
from him charging an old battery
......just sayin
ehart814
ehart814
1,655
3,645
NWPA
Installed the socket, so now I don't have to keep removing the battery cover, just plug in.View attachment 40134View attachment 40135
I bought one of these not long ago cuz my cheapie tusk trickle charger gave up the ghost. The junior works awesome. I use it for my Harley. The tusk was showing the green light on but the bike was dead. Would barely turn over once. Put the junior on it and the next time I tried starting it, it fired up like the battery was new.
Reactions: trigger
Mudder
Mudder
11,692
88,500
CTEK charger brought back a 2 and a 3 yr battery, found cigarette lighter plug and pigtail adapters as accessories.
IMG 3867
Reactions: trigger
