I have a less than a year old 520 that won't crank after sitting 3 or 4 days. It just started doing it a couple of months ago. I thought it was the wetsounds soundbar so I put a keyed in line switch on the positive wire and it's still doing it. I have a kfi winch and two led lights all wired through a key on wire. I unhooked the battery and put my tester on the positive post and touched each negative wire separately. The main ground showed about 0.10 volts. The ground to the soundbar showed about 0.45 volts and winch ground about 0.30 volts. The battery itself is 12.44 so I left it unhooked and will check it tomorrow. Am I doing this right and should I do anything else? Thanks
