P1000 Battery upgrade
Shelly
178
493
So looking to upgrade factory battery and possibly add a second battery on my 1000-5 LE. Any suggestions? Thanks
Reactions: Lady01
annoyed
annoyed
86
282
USA
My oem battery failed recently. I’m putting the same exact battery in once the UPS fairy brings it here.
Settled on an Interstate AGM deep cycle for the secondary. Originally wanted to keep both the same brand, however the 35ah of the DCM0035 couldn’t be beat.
Reactions: Lady01
AZRocks
AZRocks
111
217
Phoenix
[/QUOTE]
I'd go with the same Yuasa OEM battery since it's regarded as a very good battery. My quick look at the Interstate DCM0035 mentioned by #annoyed above shows it is 7 3/4" in length which won't fit in the compartment under the hood.
Reactions: Lady01
annoyed
annoyed
86
282
USA
It’s a tight fit, but it fits. Haven’t wired it in yet as I’m waiting on other parts still.
Agm doesn’t care how it’s mounted.
BA73AB46 5D8A 478F 8519 DCB8B5EE0309BD728D32 DB08 4F26 9819 93E0D3225032
Reactions: Lady01
annoyed
annoyed
86
282
USA
😁 I spent probably a month reading about batteries and dimensions while stuck at home sick (can’t move around much so excess of free time). That’s about the largest battery that’ll fit the box with no mods.
I’m going to have a ton of projects to do soon 😂
Not to get too far off topic, but I need to finish fabbing up the bumper brackets for my 30” light bar (take off from an old truck), install the 2-way radio into the pioneer, wire everything up. Going to run everything through a 40 amp relay that’s triggered off the cigarette plug on the dash (so it only powers accessories when the sxs is running). From there to a blue sea fuse block and then to various relays or switches.
Not a huge fan of electrical work, but it is one of the things I don’t eff up too often.
Reactions: Lady01 and TripleB
Shelly
178
493
Thanks for sharing the pics. Visuals are always good for me.
Reactions: Lady01
JenElio
JenElio
64,364
603,716
Loxahatchee, florida
JenElio
JenElio
64,364
603,716
Oh and it fits nice and snug! Haven't had any issues with it popping out of place (just sits there)
Reactions: Lady01 and Coeus
TripleB
TripleB
11,712
99,439
Caryville, Tennessee
Reactions: Lady01 and JenElio
annoyed
annoyed
86
282
USA
I came very close to buying the mighty max battery instead of the interstate battery.
In the end I decided I wanted the extra AH; that and I’ve had very good luck with interstate batteries in various vehicles over the years. Wanted something I can trust to run my gear when it’s needed.
Vikes79
Vikes79
SKOL!
10,881
105,570
South Dakota
  2. Talon X4 LV
Alright FWIW this is what a few others recommended when I was looking for my second battery. I've been running it for a yr now and no problems what so ever. Not bad for the price!
X2 I've had it for 2 years now.
Got 3 years on the same plus OEM battery. Does everything I need.
I work the aux battery pretty hard during plowing snow. Not a lot of long pulls but a crap load of up and down , left and right on the hydro turn on the same battery.
Shelly
178
493
Thank you for the information. Did you have to do any mods to get that to fit or?
Reactions: Lady01
annoyed
annoyed
86
282
USA
The mighty max will drop in, the interstate drops in as well, just on its side
Reactions: Lady01
Shelly
178
493
Ok in addition to the spare battery what else do I need to hook it up properly besides the battery cables?
Reactions: Lady01
annoyed
annoyed
86
282
USA
Blue seas system fuse block with the ground built in is a good way to connect accessories.
If you are going to run a winch, a ground bar is helpful for connecting it.
I made my own cables to minimize extra length that I would have to deal with; used a hammer crimper, terminals, and wire from Amazon.
Reactions: Lady01 and Shelly
