P1000 Bent Front Lower A-Arm; Options?
thirdparty
68
96
USA
I hit a hidden stump in some grass and bent the driver's front lower A-Arm pretty good. I know I could just replace the A-Arm fairly easily, but looking for thoughts, opinions, sh*tposts for other options and things to look out for while replacing it.
What other damage should I be on the lookout for (see pic of compressed bushing)? Also, I assume I can just bend the aluminum guard back into fit.
What's the best place to get parts for the 1000-5 LE? Also, is the same part on the 1000-5 non-LE version? I don't mind painting if someone has some takeoffs sitting around.
Thanks for your help in advance.
Bonus pic of Pioneer in its natural environment below.
PXL 20201213 144719526
PXL 20201213 144724940
PXL 20201213 144743143 1
PXL 20201213 144721863
IMG 20200919 080013 1
57,280
Bonus pic of Pioneer in it's natural environment below.
View attachment 241286View attachment 241284View attachment 241286
Arms are the same on all the Pioneer 1000 models except for the red powdercoat on the LE models and the aluminum guards. I've still got my old stock arms laying in the shed somewhere, where are you located?
tdhanses
tdhanses
1,044
3,553
Kansas
If you don’t want stock look at superatv arms, cheapest will be just replacing stock.
Reactions: JenElio and TxDoc
AZRocks
AZRocks
111
217
Phoenix
I recently installed highlifter a-arms front and rear. Perfectly happy with them. Steering is actually a little tighter/less wander. Many folks like the SuperATV arms because they are adjustable, so if you are running a lift you can get it aligned properly. I installed the highlifters and didn't even need to adjust toe in/out. They were a good fit. Just have keep them greased and check for play as the bushings wear. My two cents.
Reactions: JenElio
thirdparty
68
96
USA
Ours are beefy as hell, and have a lifetime warranty. You can hit that tree or run it off a cliff as much as you want...if you bend it...we'll shoot you a new on. Good luck though! Lol! They can take a helluva beating.
Hit me up if you're interested, and I'll get you the forum member discount.
Thanks, I looked at them at the link. I understand they give you additional ground clearance. Is the ground clearance the same as the overall lift to the machine? For example, if the ground clearance is 2 in. is the height of the machine raised 2 in.? Or is it somewhere in between?
I'm not interested in lift right now, but maybe if the ground clearance increase came with a modest lift, I might be interested.
Thanks for chiming in.
Reactions: SuperATV and TimG
ToddACimer
ToddACimer
Pioneer 1005-2
3,569
14,657
Oshkosh, Wi
SuperATV arms will not make your machine taller, they just have an arch to provide more ground clearance outside the differential and inside the tires.
I'm on 30s with SuperATV arms and you can see I'm not super tall.
PXL 20201205 222419716
Also note the arched arms. I have both front and rear
PXL 20201205 222426952
Has a little camber without the crew in it
PXL 20201205 222410396
tdhanses
tdhanses
1,044
3,553
Kansas
Stock vs SATV arms, best comparison I have. You can see they arch and provide extra clearance, no lift but they do move your wheels 1.5” forward.
38B11C31 47FA 4D62 98D1 D4E9BB04F45E
8D98AB11 5997 4CF0 BF91 E457118C1D6E
P1K5Dave
P1K5Dave
2,186
8,182
Petoskey, MI
From the pics, it looks like your frame tabs got tweaked where the arm attaches (?)
thirdparty
68
96
USA
I didn't think so, but I'll put a square on it next time I'm out there.
