Best 5-point harness for comfort and safety.
Jmaxx1502
Jmaxx1502
115
151
Cocoa beach
Looking for a easy to use, comfortable, quality 5-point harness for my 2021 X4 LW.
106,235
I use a 4 point with seatbelt style latches. The Boss really likes them over the standard latches.
@Tramguage1 uses 5 points. I cant remember the brand tho.
JenElio
JenElio
64,651
605,742
Loxahatchee, florida
I think they are only 4 point, but I've seen a few people use the can-am retractable harnesses. Way more comfortable then the standard "strapped in" feel. (nomo)
106,235
The Caned Ham harness are cool. A buddy has a CH. the only issue is when mud gets in them. They dont retract for $hit. Turned me off to them
Reactions: JenElio
DRZRon1
DRZRon1
852
2,744
I went with the 4 pt..50 caliber 3" harnesses
car type latches were a no go as mud is impossible to keep out of the latch mechanism even with full windshield
at first I was kicking myself not going with the 2" as the 3" seemed bulky, but very comfortable, mud doesn't affect latching, and they clean up very well with the garden hose.
I personally want to be strapped down tight, nets always up. seen to many bad injuries with no belts, loose belts, arms crushed.
wifey has never complained about them....
Bigshow
Bigshow
162
729
I have used Pro Armor 3" wide since 2014 when I bought my Maverick. ?Now have them on driver side of Talon. My Ex like the 5 point, our son does not, hence why only driver side of Talon. I am looking at getting a smaller 5 point to try for him as the 3" is to wide for all the bigger he is. So for now he uses stock seat belt, but he would rather ride his quad than with Dad in the Talon so he does not go with me on rough rides for now.
T-4
Just bought the 5 pt Simpson D3 Offroad Harnesses in 2" because of their 3 part tie in system and their history and reviews. I have a couple friends who have them and they are both sold on them after some use.
I bought them with the silver hardware rather than black so they were easy to spot to hook up. As soon as the new Talon arrives I will install them in the front seats. I bought the 2" for comfort.
The Simpson folks were easy to get information and order from. If you are a veteran they have a discount available, also. Since they make them to order in this one, it arrived on my doorstep in 13 days.
Sorry I don't have more first hand experience, but will update all my mods down the road a few months.
Hometeam
Hometeam
941
3,721
Normal, IL
I also vote for the Simpson D3. Been quite happy with ours. I show how to add a bar for the 5th pickup point on the passenger side in the video.
This is what I have in all 3 of my machines. The way they buckle is easier to me and the comfort is top notch. I found a bar under the seat to attach the 5th to on both sides. These also work really well in 4 point which how I run them most of the time. If I am really going hard then I buckle the 5th point. I have some DragonFire harnesses that I did not like at all and will sell to anyone that wants them....
5,039
22,559
Another fan of the Simpson D3. I like them because the left pair and right pair are connected so you're only dealing with 3 'ends' - left, right and crotch. I got exposed to another 5 point harness and all 5 ends were separate and had to be connected every time you got in. Three connection points are waaaay easier to deal with than five (duh).
I
iloehr99
44
64
Southern Indiana
I have the can ams retractable ones rigged up in mine. Best thing ever. I keep mine clean and they haven't had any issues. Flipped it two different times and they held both me and the passenger strapped tightly to the seat. I also wired the driver side seat belt to the safety switch so the belts have to be clipped to go fast. It's annoying sometimes, but it keeps my stupidity safe.
Kawboy17
Kawboy17
11
North East Indiana
Just bought 2 of each from .50 cal… several different colors, couple widths. Easy install easy to use an if ya race it they will comply with the promoters safety standards.
AD8BC0FF 981E 4D47 AECE 7A062AE43073 1523DBB3 644C 41E9 AC61 A4172BA5E400
Reactions: JenElio
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
Would you share pictures of your can am belt installed?
I was thinking about retractable harness and would like to see what you done.
K
KenThompson
265
603
Mulino
I did the Polaris retractable belts that are 6 point. They prevent you from sliding out forward during a crash
Jmaxx1502
Jmaxx1502
115
151
Cocoa beach
Yeah not familiar with the retractable harnesses. Do they mount the same?
I
iloehr99
44
64
Southern Indiana
First I'll put the pictures of them mounted on the stock cage. I had to weld a piece of angle iron on top of the belt retractor to make it fit. If you do this, Make sure you soak the whole thing in water and do short welds, or you'll melt the belt. I also had to heat up the plastic behind the seat and bend it back to make room for the inner belt. There's a picture of all the seats out that you can see where the plastic has been melted and reshaped. Doesn't look very good but you can't see it behind the seat.
Canam Seat Belts Stock Cage
Canam Seat Belts Stock Cage2Canam Seat Belts Stock Cage3Canam Seat Belts Stock Cage4Canam Seat Belts Stock Cage520191230 171638
I
iloehr99
44
64
Southern Indiana
Here is pictures with them installed on a new cage I had built. With the bar going across the back, setup was way easier. You don't have to do any welding or fabricating to the stock can am belts. Just had to bolt that flat stock on and drill two holes in it and used the stock stud and nut on the belt retractor.Canam Seat Belts New CageCanam Seat Belts New Cage1 Canam Seat Belts New Cage2 Canam Seat Belts New Cage3
