P700 Best Led headlights
Rayger143
Rayger143
3,075
26,993
Winfield, BC Canada
Hello
I drive in the dark with my pioneer 700 alot. I don't like the brightness of the stock headlight bulbs. Does anyone know a really bright, good quality led headlight bulb that they would recommend or have tried.
Thank you
115,291
Hello
Thank you
86D694AE 4B63 4B86 B2BB 93024F73A6D0
Your key to a brighter future!
03mossy
03mossy
281
1,112
MN
  2. Other Brand
kevinpo
kevinpo
38
173
Spokane Valley WA
I had the same feeling so. I don't know if these are the best but I bought a pair of them on Amazon for $40. They were direct replacements. Took about 5 min. to replace them. I am quite happy with them.
Stark Industries 880/881/893/899 Phantom Series 66W LED Headlights Conversion Kit 6000K White IP68 Waterproof.​
Regards,
Kevin
New headlight
KevP700-4
KevP700-4
249
610
Northern MI
https://www.amazon.com/Stark-UPGRADED-80W-Light-Conversion/dp/B01LDZCKGW?tag=sxsweb24-20
We used these. Work GREAT! Picked this model Stark as they do not need the cooling fan, newer model as well.
Really like them as they run cool in the light fixture, easy install, fit very well, $40, put out a nice light pattern, very bright.
Buggyman
Buggyman
44,123
357,418
ne. ohio
what year is your 700. the lights won't fit a 2014
KevP700-4
KevP700-4
249
610
Northern MI
Buggyman, sometimes you can trim the tabs on the new bulbs to fit older style sockets. I’ve done this on a few cars, the last was a Honda Accord switching from H9 to H11 bulbs to brighten the low beams. I used a pair of wire snips to trim the bulb tabs. The result worked very well. Give it a go, you will like the LEDs.
Reactions: Buggyman
Buggyman
Buggyman
44,123
357,418
ne. ohio
The 880 series has a large heat sink on them. I would have to cut the housing up then the dust cover won't work. Original bulb is GE 862, Honda didn't know what it was so I had to pull 1 to see.Screenshot 20221012 171241PXL 20221003 190351612
Buckshot07
Buckshot07
21,627
218,224
PA
The 880 series has a large heat sink on them. I would have to cut the housing up then the dust cover won't work. Original bulb is GE 862, Honda didn't know what it was so I had to pull 1 to see.View attachment 358526View attachment 358527
@buggyman,
This should solve the issue on your 2014.
….at least it did for the guy in the first review.
  • Love
Reactions: Buggyman
Buggyman
Buggyman
44,123
357,418
ne. ohio
Reactions: Buckshot07
