Best sub compact cordless impact for removing lugs?
M12 3/8 Stubby will kill anything out there.
Routinely takes off Pioneer and Talon hub nuts with 3/8-1/2 adapter and deep well impact socket. $279 with batteries.
Reactions: rtn001 and TripleB
Hometeam
Hometeam
938
3,696
Normal, IL
To the OP...I definitely think if you don't already have some power tools brand that you already own, that it is important to think through what you all want and keep the tools in the same brand and battery setup. I have these with me on virtually every ride I go on.
20210708 205403
rustyneversleeps
rustyneversleeps
381
1,833
Montana
That mini saw is bad ass!!
Reactions: rtn001 and Hometeam
JAL
65
218
Medford, OR
Looking for a compact impact driver for changing tires? But they seem to powerful for the torque needed to remove/install. Is there one that the torque is adjustable? I think the Honda recommended torque specs are 80lbs?
The impact driver is nice for getting nuts off and quickly getting nuts down. In general, I usually final hand torque by feel and then throw on a torque wrench to check my work. Drive, have fun, then re-torque. After a while I can almost set the torque by feel, especially useful in the field. My mechanical experience is mostly building aircraft, so I tend towards process overkill.
MVH
17
MI
They make torque sticks that look like a 6" 1/2 drive extension that limit the torque from an impact tool. I'm not sure if they make one for the exact torque but I think I remember seeing 100 lbs.-ft.
Reactions: rtn001
bs4u00
30
46
WI
Agreed, get one that matches your other cordless tools. Then they all use the same batteries.
I have a variable speed Makita and it works great. Finish off with a torque wrench to know where you're at. If you don't already have a cordless drill, get a combo pack with as many tools as your budget allows. Impact, drill, sawzall, circular saw, etc.
Reactions: rtn001 and CID
SMS
SMS
Pine Mountain Club
Love my 3/8 drive RYOBI. Small light weight but powerful.......
Reactions: rtn001
Jmaxx1502
Jmaxx1502
115
151
Cocoa beach
I bought the ryobi 3/8 and it couldn’t take off my lug nuts in any setting? Am I doing something wrong?
Reactions: rtn001
Jerryg
Jerryg
10,628
86,053
NEPA
I recently bought the Milwaukee M18 stubby. I chose it because I already have a M18 screw gun.
So far it's been impressive. Took the blade bolts of my Honda lawn tracor with no problem.
Reactions: rtn001
