P1000 bigger tires
hatch1990
Illinois
i bought a set of 28x10x14 system 3s xtr370s and was wondering if i needed to add wheel spacers
Reactions: Lady01
115,779
No, but pics or it didnt happen!
Oh, your first post too! Welcome from the State of Michigan!
Reactions: Lady01 and Russ989
SP82
SP82
101
356
CA
You don’t have to have them but the pioneer 1000 rear axle is narrower than the front , not noticeable in stock trim because the rear wheels are wider. With our spacers you’ll be about 2” skinnier in the back. I ordered 1” spacers from rb3offroad for just the back to even the track width out. Looks better and I’m sure will handle better. Good luck.
PJon
PJon
792
3,215
Arizona
If you put them on stock wheels no. If you have aftermarket wheels which are all the same size, adding 1” spacers to the rear only will even out the f/r track. Make sure that the spacers have 12 mm x 1.5 studs. RB3 Off Road makes a spacer that you don’t have to grind off the ends of the studs and lug nuts to get the wheels to mount flush to the spacers.
Reactions: Lady01
