P500 Brake pedal mod
hondasrule
hondasrule
50
195
ontario
[GALLERY=media, 3114Hi everyone Here is a easy mod I wanted to share with you that lets you stretch your left leg out quite a bit more but only if you are willing to bend your stock brake pedal. I used acetylene torch to glow it red and bent the pedal arm over approx. 30 deg.(top line) Once it was bent I used angle grinder with zip cutting disk and trimmed the two vertical sides of pedal .(bottom two lines)
this really worked great for spacing and there is no noticeable difference in brake function.
R-Lamm
R-Lamm
315
242
South Carolina
Way to think outside the box! Definitely need to take any advantage we can of real estate on the P500s for sure!!!
Thanks
