Brakes 2018 1000m5
jdgriner
jdgriner
37
100
Pacific Mo
Where do yall get your brakes from, mine has only 400 miles and my pads are completely gone. Metal on metal.
Sent from my Pixel 3 XL using Tapatalk
TripleB
TripleB
12,121
103,511
Caryville, Tennessee
The left shift paddle is your brake pads friend. I got 2900 miles out of my original set. Somewhere around a 1000 miles out of my race driven set. Around 700-800 miles out of my $30-$40 set of pads off my Amazon set. Im going back to OEM brake pads from now on.
TripleB
TripleB
12,121
103,511
My 2018 pads lasted nearly 1500 miles but I went with some el cheapo pads from Amazon or Ebay this time. Only a couple hundred miles so far, but no problems yet.
@JenElio
I figured out what my noise was plus the reason my rear wheels were slanted In so much. Rear Wheel bearings and brake pads were gone.
20200604 183345
JenElio
JenElio
66,699
621,954
Loxahatchee, florida
@JenElio
I figured out what my noise was plus the reason my rear wheels were slanted In so much. Rear Wheel bearings and brake pads were gone. View attachment 206615
You think the bearings would've lasted longer with the grease zerks mod? I was thinking of doing that soon. I never ask how many miles on your rig but it sounds like you got a good stretch out of them bearings n pads
jdgriner
jdgriner
37
100
Pacific Mo
From what I have heard go factory,you must ride alot of mud I have 6200 miles 1/4 left
Yep, my subdivision has 60 acres of land that is in the flood plan so they can't build on it.... Its lots of muddy fun... We are on the river so we have our own beach lots sand also.
My neighbors 2019 500, only has 300 miles, we're going to replace our Brakes at the same time
jdgriner
jdgriner
37
100
Pacific Mo
So... I'm hearing lots of factory oem suggestions? I'm my opinion they just didn't last long, think anyway I could get them to honda to warranty them out? I think the first brake inspection is supposed to be 1500 miles.
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
Could try but afraid they will say that's normal wear item
Reactions: jdgriner
wrhii
wrhii
302
1,758
Florida
I think your pads and caliper were prolly holding the wheel on. Trying to keep 5 of these things running, my experience is that with aftermarket pads (EBC), you get half or a little less then half of actual braking material then that of the oem. I was changing pads every 2 months on a few of the rigs. So back to oem it was.
"Free advice, freely given". 🤷‍♂️ 😬😬😬
0860silverado
947
1,817
louisiana
Strangely enough, my factory installed front pads were toast after 1200 miles, no mud or water, ever. Reluctantly replaced with Honda OEM pads. Over 10,000 on machine (about 8,000 on replacement pads) and still no squeaks. Maybe Honda uses crap pads on factory units to save costs? Dunno, but my genuine Honda replacement pads are serving me quite well.
jdgriner
jdgriner
37
100
Pacific Mo
Any clue on what the part number would be for Honda OEM pads? Where can I order them from?
57,560
My rears were squealing like a pig at 1100 miles and they saw a good bit of mud but not a lot of sand. OEM fronts still had about 1/4 life left but I replaced them with Race Driven anyway and threw them in my parts box for spares. Mine were shot and I didn't feel like waiting on OEM so I tried Race Driven for this go around.
This is from RMATV:
1591713589234
1591713670432
My rear OEM pads at 1190 miles. Not metal to metal yet but damn near on the inside pads:
1591713808588
I
ImHowl
14
77
Connecticut
Its crazy seeing the differences in miles people get out of pads. 1500 mi on my machine, OEM pads from the factory, and I have easily 1/2 of the material left on all pads front and rear. I wonder what it is about some machines that eat pads.
Reactions: wrhii
Ohio4x4
Ohio4x4
I brought the dishwasher
1,502
15,102
I would say terrain is a big contributor right up there with the weight of your machine and how you run it. I wasnt to shocked to get less than 1k miles out of mine. I had the same issues with my rancher. I know people with thousands of miles on there stock pads. I was replacing mine about every 1k miles. I run the $hit out of my stuff and spend a good deal of my riding miles in mountainous areas where mud is common. The rest is high speed road use around the house. For what it's worth I've had great luck with the aftermarket pads. They only last half as long but the price difference makes it worth changing them more often to me. I just keep a spare set on hand.
G
golfer1
117
269
Alabama
Wow that's pathetic getting 1500 to 2000 miles out of a set of brake pads. My rig is new but I gotta keep that in mind.
jdgriner
jdgriner
37
100
Pacific Mo
I only have 3 hundred on mine when mine started squeaking.. Same with my Neighbors
Isaiah
Isaiah
2,191
6,964
Altamont TN
I got 1,850 miles out of mine. I went to my local dealer because I didn't want to wait. But like @TripleB said, the left paddle shifter is your brake pedal;)
Reactions: TripleB
208,135
MUD! Been there done that!
Reactions: Isaiah
