Can you lock up your rear tires? One of the features that really impressed me when I test drove the Talon R, was under hard braking entering a turn. It stopped straight ahead. My RZR 1000 would have locked the rear tires. I would have had to start pumping the brakes and counter steering the yawning rear end. The i4WD traction control system is a form of anti-lock braking. The balanaced breaking system is remarkable because it allows the front tires to lock, but not the rear. Max braking since in soft soil conditions the front tires are furrowing and piling up loose material in front, but since he rear isn't locked, you don't lose your control, it stops straight ahead. It's frankly better than "ABS"
The i4WD traction control is probably the other least advertised but fantastic feature, which unless you have run another machine over the same slippery dirt road around a corner, you probably won't even notice how remarkably it works. It almost eliminates drift.
View attachment 169479 View attachment 169480
