P1000 Budget 28 x 9/11 x 12 tires
Vikes79
Vikes79
SKOL!
10,887
105,615
South Dakota
  2. Talon X4 LV
Curious if any one has experience with either of these knock off tires.
Mostly looking for something that has good snow and mud traction. I’ll trail ride in the Mountains maybe 10% of the time other wise it’s farm/ranch duty spraying, fencing etc.
Mud in my area is this soul sucking loam that has no bottom. Once you break the sod surface it’s pretty much over as you end up high centered. If you need to cross a creek or mud puddle you better be hauling tail before you get to the edge of the mud or you won’t make it.
Any other budget tires worth considering in 28” tall flavor for 12” stock rims?
I may still go with the stock size in a gbc dirt tamer, but would like a bit more height.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Those sunf tires look just like the gbc... part of me says they all probably come from the same place. But those also dont look a whole lot cheaper than the original.
If you want a good mud tire that's not obnoxious when its dry look at the Bear Claw HTR. They are a great option and not insanely expensive.
Reactions: TripleB and Vikes79
Vikes79
Vikes79
SKOL!
10,887
105,615
South Dakota
  2. Talon X4 LV
I was thinking the same on the sunf tires. Probably come the same factory.
As far as cost the two above can be found cheaper...just not sure if they are worth it.
I’ve been watching the blem list from Interco for a while now.
Vikes79
Vikes79
SKOL!
10,887
105,615
South Dakota
  2. Talon X4 LV
Lol in my search I came across some new P1k5 deluxe take offs ( rim and tire) for 450...so I jumped on it. I’ll keep my steelies as spares.
Leukic
Leukic
314
999
Leesville, South Carolina
I purchased a set of 27inch SunF tires for my father last year. He loves them
Reactions: Backwoods
